Wired network connection fails to reconnect
I’ve had problems in the past with wireless, but never with wired connections lol. However, when I disconnect the ethernet cable and later reconnect, it fails to establish a connection. I have tried restarting the NetworkManager service, but it doesn’t help. If I reboot, the connection is up again. Could someone point me in the right direction? Thanks.
I’ve a similar problem, although I’ve found out that Tailscale has some relation to the problem in my case
FWIW, doing
sudo ip link set enp2s0 down
will reset it, using your own interface name.
