Enabling or disabling core dumps system-wide is a little finicky. You have to set both systemd extra options and PAM limits, and you may also want to mess with the kernel.core_pattern sysctl option. I wrote a local module to make it as simple as possible, so that I can have them usually be off but easily enabled for troubleshooting:
core dump control module
{ lib, pkgs, config, ... }:
with lib;
imports = [];
options.coredumps = {
enable = mkEnableOption "capturing core dumps";
limit = mkOption {
type = types.ints.positive;
default = 2097152; # 1G worth of 512-byte abstract disk blocks
description = "Maximum size for core dumps, when enabled.";
config = mkMerge [
# No matter what, we don't want systemd messing with core dumps.
systemd.coredump.enable = false;
# Settings when core dumps are on.
(mkIf config.coredumps.enable {
systemd.extraConfig = ''
DefaultLimitCORE=${toString config.coredumps.limit
}:${toString config.coredumps.limit}
security.pam.loginLimits = [
domain = "*";
item = "core";
type = "-";
value = "${toString config.coredumps.limit}";
boot.kernel.sysctl."kernel.core_pattern" = "/var/crash/%e.%p.core";
systemd.tmpfiles.rules = [
"d /var/crash 0700 root root 14d -"
# Settings when core dumps are off.
# For some reason, there isn't any such thing as mkIfElse.
(mkIf (!config.coredumps.enable) {
DefaultLimitCORE=0:0
domain = "*";
item = "core";
type = "-";
value = "0";
# To prevent the kernel from ever generating core dumps, make it
# try to write to a nonexistent directory. It doesn't work to specify
# /dev/null; that will cause the kernel to *replace* /dev/null with the
# core dump if a process running as root dumps core.
boot.kernel.sysctl."kernel.core_pattern" = "/nonexistent/core";
I’m tempted to propose this for inclusion in NixOS proper. Obviously it would need to be made quite a bit more configurable, but before I do all that work I thought I would ask here whether anyone besides me would find such a thing useful.
