I’m working on a NixOS config and I need to do some special setup for my VM when a check runs.
In practice, this is for setting up qemu tap networking in a netns.
For this example, I just want to print “Hello” on the host before the VM starts and “Goodbye” after the VM closes.
Here’s my Flake:
inputs.nixpkgs.url = "github:nixos/nixpkgs/nixpkgs-unstable";
outputs = { self, nixpkgs, ... }:
system = "x86_64-linux";
module = { pkgs, lib, ... }:
config = {
services.getty.autologinUser = "root";
virtualisation.vmVariant.virtualisation.graphics = false;
boot.loader = {
systemd-boot.enable = true;
nixpkgs.hostPlatform = system;
system.stateVersion = "23.11";
fileSystems."/" = lib.mkVMOverride { device = "/dev/vda1"; fsType = "ext4"; };
checks.${system} =
"example-check" = (nixpkgs.lib.nixos.runTest {
name = "example-check";
hostPkgs = nixpkgs.legacyPackages.${system};
node.specialArgs = { inherit self; };
nodes = {
machine = { pkgs, ... }: {
imports = [ module ];
environment.systemPackages = [ pkgs.coreutils ];
testScript = ''
start_all
machine.wait_for_unit("multi-user.target")
output = machine.succeed ("true")
print(output)
}).config.result;
This passes nix flake check -Lv
just fine.
I can also build it with nix build 'path:.#checks.x86_64-linux.example-check.driver' -Lv
to check the scripts generated by the build process.
When I do, this is the generated result/bin/nixos-test-driver
#! /nix/store/5l50g7kzj7v0rdhshld1vx46rf2k5lf9-bash-5.2p26/bin/bash -e
export startScripts='/nix/store/xjzm6al5pgpnp1kgj56j3hsqvqm4cvr2-nixos-vm/bin/run-machine-vm'
export testScript='/nix/store/hkw2fx5sf586nwhinzav9ck1n3gcyvh1-nixos-test-driver-example-check/test-script'
export globalTimeout='3600'
export vlans='1'
exec -a "$0" "/nix/store/hkw2fx5sf586nwhinzav9ck1n3gcyvh1-nixos-test-driver-example-check/bin/.nixos-test-driver-wrapped" "$@"
When I inspect run-machine-vm
, I get the qemu vm launch script I expect.
I thought the solution might look something like this, but it causes infinite recursion:
nodes = {
machine = { config, pkgs, lib, ... }: {
system.build.vm = lib.mkForce (pkgs.runCommand "custom-vm" { buildInputs = [ pkgs.coreutils ]; } ''
cat > run-vm.sh <<'EOF'
#!/bin/sh
echo "Hello"
${config.system.build.vm}/bin/run-*-vm
echo "Goodbye"
EOF
chmod +x run-vm.sh
mkdir -p $out/bin
cp run-vm.sh $out/bin/run-custom-vm
environment.systemPackages = [ pkgs.curl pkgs.coreutils ];
Another idea was to add a wrapper module as nodes.machine.imports = [ module wrapVMModule ]
, but this too causes infinite recursion:
wrapVMModule = { config, pkgs, lib, ... }:
system.build.vm = lib.mkForce (pkgs.writeShellApplication {
name = "vm-wrapper";
text = ''
set -euxo pipefail
echo "Hello"
echo "Goodbye"
What is the idiomatic way to wrap the check VM launcher so I can do my setup/teardown?
I think if I could somehow wrap system.build.vm, I could do the setup I need.
If I was to fork nixpkgs, I’m sure I could add what I need, but that seems excessive (maybe not?).
I also thought I might be able to manipulate options.definitions
directly, but this is not visible under checks.x86_64-linux.example-check.config.nodes.machine
in the repl.
Any guidance is appreciated
