I have quite some issues with getting my X resolution persistent with nvidia.
When configuring the monitor with nvidia-settings
the applications are fine and the file also seems to look ok:
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 550.67
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/input/mice"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
# HorizSync source: edid, VertRefresh source: edid
Identifier "Monitor0"
VendorName "Unknown"
ModelName "Samsung Odyssey G95NC"
HorizSync 275.0 - 275.0
VertRefresh 48.0 - 120.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device0"
Driver "nvidia"
VendorName "NVIDIA Corporation"
BoardName "NVIDIA GeForce RTX 3080"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DP-0"
Option "metamodes" "7680x2160_120 +0+0"
Option "SLI" "Off"
Option "MultiGPU" "Off"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
When I restart the session I get thrown back to 3840x1080
When quering xrandr:
[beat@smolboi:~]$ xrandr -q
Screen 0: minimum 8 x 8, current 7680 x 2160, maximum 32767 x 32767
HDMI-0 disconnected primary (normal left inverted right x axis y axis)
DP-0 connected 7680x2160+0+0 (normal left inverted right x axis y axis) 1mm x 1mm
3840x1080 59.97 + 119.97
7680x2160 120.00* 59.99
5120x1440 119.97 59.98
3840x2160 119.88 59.94 29.97
2560x1440 120.00 59.95
1920x1080 119.88 60.00 59.94
1680x1050 59.95
1600x900 60.00
1440x900 59.89
1280x1024 75.02 60.02
1280x800 59.81
1280x720 60.00 59.94
1152x864 75.00
1024x768 75.03 70.07 60.00
800x600 75.00 72.19 60.32
720x480 59.94
640x480 75.00 59.94
DP-1 disconnected (normal left inverted right x axis y axis)
DP-2 disconnected (normal left inverted right x axis y axis)
DP-3 disconnected (normal left inverted right x axis y axis)
DP-4 disconnected (normal left inverted right x axis y axis)
DP-5 disconnected (normal left inverted right x axis y axis)
None-2-1 connected (normal left inverted right x axis y axis)
1024x768 60.00 +
HDMI-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-1 disconnected (normal left inverted right x axis y axis)
DP-1-2 disconnected (normal left inverted right x axis y axis)
my nvidia config is pretty much what nixos wiki is proposing for defaults.
also I’m running gdm which seems to use the same low resolution, for which I neither have found a way so far to set it correctly.
is the nixos xserver module overriding the settings? I also tried to set it with xrandrHeads
but that did not work at all. (Would that be the preferred approach to set X configurations?)
