{ pkgs, ... }:
yazi-plugins = pkgs.fetchFromGitHub {
owner = "yazi-rs";
repo = "plugins";
rev = "55bf6996ada3df4cbad331ce3be0c1090769fc7c";
hash = "sha256-v/C+ZBrF1ghDt1SXpZcDELmHMVAqfr44iWxzUWynyRk=";
programs = {
yazi = {
enableZshIntegration = true;
shellWrapperName = "y";
# package = pkgs.yazi; # Comment if using the git package
flavors =
gruvbox-yazi = (
pkgs.stdenv.mkDerivation {
pname = "yazi-flavor-gruvbox";
version = "24.4.25";
src = pkgs.fetchFromGitHub {
owner = "bennyyip";
repo = "gruvbox-dark.yazi";
rev = "91fdfa70f6d593934e62aba1e449f4ec3d3ccc90";
hash = "sha256-RWqyAdETD/EkDVGcnBPiMcw1mSd78Aayky9yoxSsry4=";
installPhase = ''
mkdir -p $out
cp -r $src/* $out/
gruvbox-dark = gruvbox-yazi;
theme = {
flavor = {
dark = "gruvbox-dark";
light = "gruvbox-dark";
plugins = {
full-border = "${yazi-plugins}/full-border.yazi";
vcs-files = "${yazi-plugins}/vcs-files.yazi";
smart-enter = "${yazi-plugins}/smart-enter.yazi";
git = "${yazi-plugins}/git.yazi";
toggle-pane = "${yazi-plugins}/toggle-pane.yazi";
keymap = {
manager = {
prepend_keymap = [
on = "T";
run = "plugin toggle-pane min-preview";
desc = "Show or hide the preview pane";
on = "l";
run = "plugin smart-enter";
desc = "Enter the child directory, or open the file";
# For vcs-files.yazi
on = [
"g"
"c"
run = "plugin vcs-files";
desc = "Show Git File changes";
settings = {
plugin = {
prepend_fetchers = [
# For git.yazi
id = "git";
name = "*";
run = "git";
id = "git";
name = "*/";
run = "git";
# For git.yazi
initLua = # lua
-- For full-border plugin
require("full-border"):setup {
type = ui.Border.ROUNDED,
-- for git.yazi
require("git"):setup()
The above is my yazi.nix configuration. The plugin module requires for the plugins to have a init.lua in their repo. However, most plugins have moved to a main.lua (initially they used a init.lua). This is not reflected in the new module. How do I fix it? How do I report this issue (total noob in this)?
Failed assertions:
- krish profile: Value at `programs.yazi.plugins.full-border` is not a valid yazi plugin.
The plugin is missing these files: init.lua
Evaluated value: `/nix/store/rfs69364g6s9h635lgba83i135k8xafa-source/full-border.yazi`
- krish profile: Value at `programs.yazi.plugins.git` is not a valid yazi plugin.
Evaluated value: `/nix/store/rfs69364g6s9h635lgba83i135k8xafa-source/git.yazi`
- krish profile: Value at `programs.yazi.plugins.smart-enter` is not a valid yazi plugin.
Evaluated value: `/nix/store/rfs69364g6s9h635lgba83i135k8xafa-source/smart-enter.yazi`
- krish profile: Value at `programs.yazi.plugins.toggle-pane` is not a valid yazi plugin.
Evaluated value: `/nix/store/rfs69364g6s9h635lgba83i135k8xafa-source/toggle-pane.yazi`
- krish profile: Value at `programs.yazi.plugins.vcs-files` is not a valid yazi plugin.
Evaluated value: `/nix/store/rfs69364g6s9h635lgba83i135k8xafa-source/vcs-files.yazi`
the above is the output of “not building”
EDIT: For some reason pkgs.yaziPlugins.<plugin> is not working either, the error gives that the yaziPlugins attribute is missing, though the attribute is defined in the all-packages.nix file.
