Hello
Today my Asus Zenbook wifi stopped working, it keeps re-connecting. I had an unreliable experience like that since forever but today it never connects. Usually it does connect and it asks to reconnect time to time but since today it never connects. I use Network Manager
$ lspci
02:00.0 Network controller: Intel Corporation Wireless 8260 (rev 3a)
I do not see the 8026 in the firmware list, but I am not sure about what to expect
$ modinfo iwlwifi
filename: /run/booted-system/kernel-modules/lib/modules/6.1.2/kernel/drivers/net/wireless/intel/iwlwifi/iwlwifi.ko.xz
license: GPL
description: Intel(R) Wireless WiFi driver for Linux
firmware: iwlwifi-100-5.ucode
firmware: iwlwifi-1000-5.ucode
firmware: iwlwifi-135-6.ucode
firmware: iwlwifi-105-6.ucode
firmware: iwlwifi-2030-6.ucode
firmware: iwlwifi-2000-6.ucode
firmware: iwlwifi-5150-2.ucode
firmware: iwlwifi-5000-5.ucode
firmware: iwlwifi-6000g2b-6.ucode
firmware: iwlwifi-6000g2a-6.ucode
firmware: iwlwifi-6050-5.ucode
firmware: iwlwifi-6000-6.ucode
firmware: iwlwifi-7265D-29.ucode
firmware: iwlwifi-7265-17.ucode
firmware: iwlwifi-3168-29.ucode
firmware: iwlwifi-3160-17.ucode
firmware: iwlwifi-7260-17.ucode
firmware: iwlwifi-8265-36.ucode
firmware: iwlwifi-8000C-36.ucode
firmware: iwlwifi-9260-th-b0-jf-b0-46.ucode
firmware: iwlwifi-9000-pu-b0-jf-b0-46.ucode
firmware: iwlwifi-BzBnj-b0-fm-b0-72.ucode
firmware: iwlwifi-gl-b0-fm-b0-72.ucode
firmware: iwlwifi-bz-a0-fm4-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-hr-b0-72.ucode
firmware: iwlwifi-BzBnj-a0-gf4-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-gf-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-fm4-a0-72.ucode
firmware: iwlwifi-BzBnj-a0-fm-a0-72.ucode
firmware: iwlwifi-gl-a0-fm-a0-72.ucode
firmware: iwlwifi-bz-a0-fm-a0-72.ucode
firmware: iwlwifi-bz-a0-mr-a0-72.ucode
firmware: iwlwifi-bz-a0-gf4-a0-72.ucode
firmware: iwlwifi-bz-a0-gf-a0-72.ucode
firmware: iwlwifi-bz-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-mr-a0-72.ucode
firmware: iwlwifi-ma-a0-fm-a0-72.ucode
firmware: iwlwifi-ma-a0-mr-a0-72.ucode
firmware: iwlwifi-ma-a0-gf4-a0-72.ucode
firmware: iwlwifi-ma-a0-gf-a0-72.ucode
firmware: iwlwifi-ma-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-jf-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-hr-b0-72.ucode
firmware: iwlwifi-SoSnj-a0-gf-a0-72.ucode
firmware: iwlwifi-SoSnj-a0-gf4-a0-72.ucode
firmware: iwlwifi-ty-a0-gf-a0-72.ucode
firmware: iwlwifi-so-a0-gf-a0-72.ucode
firmware: iwlwifi-so-a0-hr-b0-72.ucode
firmware: iwlwifi-so-a0-jf-b0-72.ucode
firmware: iwlwifi-cc-a0-72.ucode
firmware: iwlwifi-QuQnj-b0-jf-b0-72.ucode
firmware: iwlwifi-QuZ-a0-jf-b0-72.ucode
firmware: iwlwifi-QuZ-a0-hr-b0-72.ucode
firmware: iwlwifi-Qu-b0-jf-b0-72.ucode
firmware: iwlwifi-Qu-c0-hr-b0-72.ucode
firmware: iwlwifi-QuQnj-b0-hr-b0-72.ucode
firmware: iwlwifi-Qu-b0-hr-b0-72.ucode
alias: pci:v00008086d00007740sv*sd*bc*sc*i*
alias: pci:v00008086d00004232sv*sd00001201bc*sc*i*
depends: cfg80211
retpoline: Y
intree: Y
vermagic: 6.1.2 SMP preempt mod_unload
parm: swcrypto:using crypto in software (default 0 [hardware]) (int)
parm: 11n_disable:disable 11n functionality, bitmap: 1: full, 2: disable agg TX, 4: disable agg RX, 8 enable agg TX (uint)
parm: amsdu_size:amsdu size 0: 12K for multi Rx queue devices, 2K for AX210 devices, 4K for other devices 1:4K 2:8K 3:12K (16K buffers) 4: 2K (default 0) (int)
parm: fw_restart:restart firmware in case of error (default true) (bool)
parm: nvm_file:NVM file name (charp)
parm: uapsd_disable:disable U-APSD functionality bitmap 1: BSS 2: P2P Client (default: 3) (uint)
parm: enable_ini:0:disable, 1-15:FW_DBG_PRESET Values, 16:enabled without preset value defined,Debug INI TLV FW debug infrastructure (default: 16)
parm: bt_coex_active:enable wifi/bt co-exist (default: enable) (bool)
parm: led_mode:0=system default, 1=On(RF On)/Off(RF Off), 2=blinking, 3=Off (default: 0) (int)
parm: power_save:enable WiFi power management (default: disable) (bool)
parm: power_level:default power save level (range from 1 - 5, default: 1) (int)
parm: disable_11ac:Disable VHT capabilities (default: false) (bool)
parm: remove_when_gone:Remove dev from PCIe bus if it is deemed inaccessible (default: false) (bool)
parm: disable_11ax:Disable HE capabilities (default: false) (bool)
