Greetings! Nix noob here.
I’ve been using nix-darwin to manage many packages on macOS for a few days with good results, but I have run into a problem that I cannot seem to diagnose.
I added zsh-vi-mode
to my environment.systemPackages
, expecting that after a darwin-rebuild switch
, I would find its output in /run/current-system/sw/share/zsh-vi-mode
. But, it simply does not.
I’ve tested building the package in several different ways, with e.g. nix-shell
and nix build
; and in these cases the result looks correct.
% nix build --impure --expr '(import <nixpkgs> {}).zsh-vi-mode'
% tree result
result
└── share
└── zsh-vi-mode
├── zsh-vi-mode.plugin.zsh
└── zsh-vi-mode.zsh
% cat ~/.config/nix-darwin/flake.nix
zsh-vi-mode
% darwin-rebuild --flake ~/.config/nix-darwin switch --verbose --show-trace
setting nvram variables...
% ls /run/current-system/sw/share/zsh-vi-mode
ls: cannot access '/run/current-system/sw/share/zsh-vi-mode': No such file or directory
I’m grateful for any troubleshooting suggestions!
