I use btrfs with impermanence.
It uses a volume pool located in /dev/pool/root.
I am unable to access this device in a oneshot service I use to revert the root to clean state for impermanence. What can I do?
boot.initrd.systemd.services.rollback = {
description = "Rollback BTRFS root subvolume to a pristine state";
wantedBy = [
"initrd.target"
before = [
"sysroot.mount"
unitConfig.DefaultDependencies = "no";
script = ''
mkdir /btrfs_tmp
mount /dev/pool/root /btrfs_tmp
if [[ -e /btrfs_tmp/root ]]; then
mkdir -p /btrfs_tmp/old_roots
timestamp=$(date --date="@$(stat -c %Y /btrfs_tmp/root)" "+%Y-%m-%-d_%H:%M:%S")
mv /btrfs_tmp/root "/btrfs_tmp/old_roots/$timestamp"
fi
delete_subvolume_recursively() {
IFS=$'\n'
for i in $(btrfs subvolume list -o "$1" | cut -f 9- -d ' '); do
delete_subvolume_recursively "/btrfs_tmp/$i"
done
btrfs subvolume delete "$1"
for i in $(find /btrfs_tmp/old_roots/ -maxdepth 1 -mtime +${builtins.toString cfg.removeTmpFilesOlderThan}); do
delete_subvolume_recursively "$i"
done
btrfs subvolume create /btrfs_tmp/root
umount /btrfs_tmp
That comment you quoted is probably not relevant to you. I’d be surprised if disko isn’t automatically setting fsType correctly, and if it’s not then
this is doing the trick anyway.
What makes you think you’re experiencing that same issue? There can be a lot of things that cause /sysroot to fail to mount.
No, I wouldn’t expect that to be an improvement. In fact ordering after = ["sysroot.mount"]; should certainly break it. We’ll have to see some logs to know what happened.
It fails to mount /sysroot/var/lib, according to the logs.
Mounting /sysroot/nix...
Mounting /sysroot/persist...
Mounting /sysroot/var/lib...
Starting Mountpoints configured in the Real Root...
Mounted /sysroot/nix...
Failed to mount /sysroot/var/lib.
When it fails in initrd, it should give you access to the emergency shell if you have boot.initrd.systemd.emergencyAccess set. If not, you can add rd.systemd.debug_shell to the kernel params if you’re using a very recent nixos unstable, and then press ctrl-alt-f9 to go to the debug shell. From there you can use commands like systemctl status and journalctl to get a more detailed log about the mount units that failed
Alright, after some troubleshooting it seems that i was using the guest module for microvms, which messes with the systemd initrd. Now that i am no longer using it, your original solution works, thank you!
