aka: nix-distcc, nix-bazel
moved from Incremental builds - #11 by milahu
related splitBuildInstall: split buildPhase and installPhase for large packages
related Caching local compilation results for all compiled packages - #5 by jonringer
concept
1. run cmake and make in dry-run mode
2. get compile commands from compile_commands.json
3. get link commands from CMakeFiles/sometargetname.dir/link.txt
4. generate one derivation per compilation object → compile-derivations
5. generate one derivation per link target → link-derivations
6. pass compiled objects as buildInputs to the link-derivations
7. pass linked executables/libraries as buildInputs to the package-derivation
sample project
- is using cmake build tool
- has multiple source files: 7
*.cfiles - has only 1 link target - could be more, but meh
compile commands
use compiledb -n make to generate a compile_commands.json file
bear is another popular tool for this job, but bear has no dry run mode
the result of compiledb is similar to make --dry-run | grep gcc
link commands
to produce the ninvaders binary,
we need the link command in CMakeFiles/ninvaders.dir/link.txt
gcc CMakeFiles/ninvaders.dir/aliens.c.o CMakeFiles/ninvaders.dir/globals.
c.o … -o ninvaders /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so …
build tree
to parse the build tree / dependency tree
docs: cmake file api
mkdir -p .cmake/api/v1/query
touch .cmake/api/v1/query/codemodel-v2
cmake .
ls .cmake/api/v1/reply
codemodel-v2-68e4e0ffd43539f5beb8.json
directory-.-6563d967dbe05c00b1a9.json
index-2021-11-07T12-58-37-0461.json
target-ninvaders-49e8513ef38dff190c55.json
working prototype
using compile commands from compile_commands.json
and link command from CMakeFiles/ninvaders.dir/link.txt
i use symlink where possible, to reduce overhead from file copying
{ lib, stdenv, fetchFromGitHub, cmake, ncurses, python3, python3Packages, gcc }:
configurePhaseDrv =
stdenv.mkDerivation rec {
pname = "ninvaders";
version = "0.1.2";
name = "${pname}-${version}-configurePhase";
src = fetchFromGitHub {
owner = "sf-refugees";
repo = pname;
rev = "v${version}";
sha256 = "1wmwws1zsap4bfc2439p25vnja0hnsf57k293rdxw626gly06whi";
nativeBuildInputs = [
cmake
python3
python3Packages.compiledb
buildInputs = [ ncurses ];
configurePhase = ''
cd /build; mkdir build; cd build
# CMakeLists.txt -> Makefile
cmake ../$sourceRoot
mv .cmake/api/v1/reply/index-*.json .cmake/api/v1/reply/index.json
# probably the files in reply/ are not reproducible, but we could patch them
# Makefile -> compile_commands.json
compiledb -n make
cp -r /build $out
printf "%s" "$sourceRoot" >$out/sourceRoot.txt
dontBuild = true;
dontCheck = true;
dontInstall = true;
dontDist = true;
drv2 = rec {
sourceRoot = builtins.readFile "${configurePhaseDrv}/sourceRoot.txt";
sourcePath = /* lib.traceValSeq */ "${configurePhaseDrv}/${sourceRoot}";
configureResultDir = "${configurePhaseDrv}/build";
compileCommands = /* lib.traceValSeq */ (builtins.fromJSON (builtins.readFile "${configureResultDir}/compile_commands.json"));
compileObjects = lib.imap0 compileObjectOfCommand compileCommands;
compileObjectOfCommand = commandIdx: command: (stdenv.mkDerivation {
# avoid using configurePhaseDrv pname and version?
# re-use the compile-object across different versions (and pnames)
#name = "${configurePhaseDrv.pname}-${configurePhaseDrv.version}-obj${builtins.toString commandIdx}";
name = "compileobject-${builtins.baseNameOf command.file}";
# FIXME use only the needed inputs. avoid recompile when buildInputs change
inherit (configurePhaseDrv) buildInputs;
nativeBuildInputs = [ gcc ]; # note: no cmake
src = configurePhaseDrv.out;
buildCommand = ''
ln -s $src/source /build/source
mkdir /build/build
ln -s $src/build/CMakeFiles /build/build/
cd /build/build
argsRaw=(${lib.escapeShellArgs command.arguments})
# debug
if false; then
echo "command.directory = ${command.directory}"
echo "command.file = ${command.file}"
echo "command.arguments = ''${argsRaw[@]}"
fi
args=()
for a in "''${argsRaw[@]}"; do
if (echo "$a" | grep -E '^CMakeFiles/([^/]+\.dir)' >/dev/null); then
args+=("$(echo "$a" | sed -E "s,^CMakeFiles/([^/]+\.dir),$out/\1,")")
outDir="$(echo "$a" | sed -E "s,^CMakeFiles/([^/]+\.dir)/.*$,\1,")"
outPath="$out/$outDir"
if [ ! -d "$outPath" ]; then mkdir -p "$outPath"; fi
else
args+=("$a")
fi
done
echo "''${args[@]}"
"''${args[@]}"
cmakeReplyDir = "${configureResultDir}/.cmake/api/v1/reply";
cmakeIndex = builtins.fromJSON (builtins.readFile "${cmakeReplyDir}/index.json");
cmakeCodemodel = builtins.fromJSON (builtins.readFile "${cmakeReplyDir}/${cmakeIndex.reply.codemodel-v2.jsonFile}");
# TODO multiple configurations?
cmakeConfiguration = (builtins.elemAt cmakeCodemodel.configurations 0);
#cmakeConfiguration.directories[0].jsonFile
#cmakeConfiguration.projects[0].name == "ninvaders"
targets = builtins.map (target: builtins.fromJSON (builtins.readFile "${cmakeReplyDir}/${target.jsonFile}")) cmakeConfiguration.targets;
inherit (configurePhaseDrv) pname version;
buildCommand = ''
cp -r $src/* /build; chmod -R +w /build
objList=()
${lib.concatMapStringsSep "\n" (obj: ''objList+=("${obj}")'') drv2.compileObjects}
for o in "''${objList[@]}"; do
echo "obj $o"
cp -rs $o/* /build/build/CMakeFiles
done
mkdir -p $out/bin
cd /build/build
for targetDir in CMakeFiles/*.dir;
do
targetName=''${targetDir%.dir}
targetName=''${targetName##*/}
linkCommand="$(cat "$targetDir/link.txt")"
echo "linking $targetName"
echo "$linkCommand"
$linkCommand
cp -v $targetName $out/bin
done
this will build 8 derivations = 7 compile objects + 1 link target
the 8 derivations can be distributed across multiple build machines, aka distcc
build output
the build is distributed between localhost and laptop3
nix-build . -A ninvaders
building '/nix/store/dc5ikqii3rm8hpg683458z8gng5r9qpa-ninvaders-0.1.2-configurePhase.drv' on 'ssh://laptop3'...
copying 6 paths...
copying path '/nix/store/19s295848nb8z5fsx2y5vynk5jifw4yg-source' to 'ssh://laptop3'...
copying path '/nix/store/3gbknbks7f4p4fca41hrffra2xp9fnqw-python3.9-enum-compat-0.0.3' to 'ssh://laptop3'...
copying path '/nix/store/flpj82wfqpzzbvhpbakk1gksw6hziw1q-python3.9-click-8.0.1' to 'ssh://laptop3'...
copying path '/nix/store/kij2088a9jrk00v44bg59132rkyxjc09-python3.9-shutilwhich-1.1.0' to 'ssh://laptop3'...
copying path '/nix/store/rj8nvqadg13yhhy6w991nvx0m0s5cas0-python3.9-bashlex-0.15' to 'ssh://laptop3'...
copying path '/nix/store/2rvhljxwjf951sr7qb9p8rpyajk59di6-python3.9-compiledb-0.10.1' to 'ssh://laptop3'...
unpacking sources
unpacking source archive /nix/store/19s295848nb8z5fsx2y5vynk5jifw4yg-source
source root is source
patching sources
configuring
-- The C compiler identification is GNU 10.3.0
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Check for working C compiler: /nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc - skipped
-- Detecting C compile features
-- Detecting C compile features - done
-- Looking for cbreak in /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so
-- Looking for cbreak in /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so - found
-- Looking for nodelay in /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so
-- Looking for nodelay in /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so - found
-- Found Curses: /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so
-- Configuring done
-- Generating done
-- Build files have been written to: /build/build
post-installation fixup
shrinking RPATHs of ELF executables and libraries in /nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase
shrinking /nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase/build/CMakeFiles/3.21.2/CompilerIdC/a.out
shrinking /nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase/build/CMakeFiles/3.21.2/CMakeDetermineCompilerABI_C.bin
strip is /nix/store/a4mmjm3bblxwp8h53bcfx3dly80ib0ba-binutils-2.35.1/bin/strip
patching script interpreter paths in /nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase
checking for references to /build/ in /nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase...
copying 1 paths...
copying path '/nix/store/wwms9qlx94aajs5y212gyfjxzq7mwmrx-ninvaders-0.1.2-configurePhase' from 'ssh://laptop3'...
these 8 derivations will be built:
/nix/store/26w6vm64wwwdj1c2vylbryxf5i6m6qvf-compileobject-aliens.c.drv
/nix/store/3439k745qvj7isr847sxl710zpmfdl8r-compileobject-nInvaders.c.drv
/nix/store/ix6h9xfmpnjx2mwnrfcbypnx5wvmrk0y-compileobject-highscore.c.drv
/nix/store/n7zzlrlv0lfg7sywp01aryknsy7dw47j-compileobject-ufo.c.drv
/nix/store/wmfr6nqp8iamdndbyr55z08janynfy79-compileobject-globals.c.drv
/nix/store/xga02lbklrqlhq6dyvl2n0vqjh9hcjh1-compileobject-view.c.drv
/nix/store/zg0r82kghs4madc8bg2llznj2f1cpfk5-compileobject-player.c.drv
/nix/store/83phhkx13ww324khm4bippml36dpf62f-ninvaders-0.1.2.drv
building '/nix/store/26w6vm64wwwdj1c2vylbryxf5i6m6qvf-compileobject-aliens.c.drv' on 'ssh://laptop3'...
building '/nix/store/wmfr6nqp8iamdndbyr55z08janynfy79-compileobject-globals.c.drv'...
building '/nix/store/ix6h9xfmpnjx2mwnrfcbypnx5wvmrk0y-compileobject-highscore.c.drv'...
copying 0 paths...
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/w93jrqj7gsaiqkmnbw0xa2nb8j7r7iga-compileobject-aliens.c/ninvaders.dir/aliens.c.o -MF /nix/store/w93jrqj7gsaiqkmnbw0xa2nb8j7r7iga-compileobject-aliens.c/ninvaders.dir/aliens.c.o.d -o /nix/store/w93jrqj7gsaiqkmnbw0xa2nb8j7r7iga-compileobject-aliens.c/ninvaders.dir/aliens.c.o -c /build/source/aliens.c
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/hnlgzqvkalh54xnj77dr74qij9g3498w-compileobject-globals.c/ninvaders.dir/globals.c.o -MF /nix/store/hnlgzqvkalh54xnj77dr74qij9g3498w-compileobject-globals.c/ninvaders.dir/globals.c.o.d -o /nix/store/hnlgzqvkalh54xnj77dr74qij9g3498w-compileobject-globals.c/ninvaders.dir/globals.c.o -c /build/source/globals.c
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/bd3gjrq7w6g9n7msswrgbi2863zzczjg-compileobject-highscore.c/ninvaders.dir/highscore.c.o -MF /nix/store/bd3gjrq7w6g9n7msswrgbi2863zzczjg-compileobject-highscore.c/ninvaders.dir/highscore.c.o.d -o /nix/store/bd3gjrq7w6g9n7msswrgbi2863zzczjg-compileobject-highscore.c/ninvaders.dir/highscore.c.o -c /build/source/highscore.c
/build/source/globals.c: In function 'waitForReturn':
/build/source/globals.c:69:3: warning: ignoring return value of 'fgets' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
69 | fgets(b, sizeof(b), stdin);
/build/source/highscore.c: In function 'readHighScore':
/build/source/highscore.c:166:5: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
166 | fscanf(fp_HighScore, "%[^\n]\nv%[^\n]\n\n", hs_id, hs_version);
/build/source/highscore.c:181:5: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
181 | fscanf(fp_HighScore, "beginner\n");
/build/source/highscore.c:183:5: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
183 | fscanf(fp_HighScore, "normal\n");
/build/source/highscore.c:185:5: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
185 | fscanf(fp_HighScore, "expert\n");
/build/source/highscore.c: In function 'fget_HighScoreData':
/build/source/highscore.c:141:5: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
141 | fscanf(fp, "%i %s\n", &hs_e->score, hs_e->name);
/build/source/highscore.c:144:3: warning: ignoring return value of 'fscanf' declared with attribute 'warn_unused_result' [8;;https://gcc.gnu.org/onlinedocs/gcc/Warning-Options.html#index-Wunused-result-Wunused-result8;;]
144 | fscanf(fp, "\n");
building '/nix/store/3439k745qvj7isr847sxl710zpmfdl8r-compileobject-nInvaders.c.drv'...
building '/nix/store/zg0r82kghs4madc8bg2llznj2f1cpfk5-compileobject-player.c.drv'...
copying 1 paths...
copying path '/nix/store/w93jrqj7gsaiqkmnbw0xa2nb8j7r7iga-compileobject-aliens.c' from 'ssh://laptop3'...
building '/nix/store/n7zzlrlv0lfg7sywp01aryknsy7dw47j-compileobject-ufo.c.drv' on 'ssh://laptop3'...
waiting for a machine to build '/nix/store/xga02lbklrqlhq6dyvl2n0vqjh9hcjh1-compileobject-view.c.drv'...
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/hr7fcqp4kfl4lba9kzdjb0cisxx1mgnq-compileobject-nInvaders.c/ninvaders.dir/nInvaders.c.o -MF /nix/store/hr7fcqp4kfl4lba9kzdjb0cisxx1mgnq-compileobject-nInvaders.c/ninvaders.dir/nInvaders.c.o.d -o /nix/store/hr7fcqp4kfl4lba9kzdjb0cisxx1mgnq-compileobject-nInvaders.c/ninvaders.dir/nInvaders.c.o -c /build/source/nInvaders.c
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/mgb2zjqqvx7sslj6q97qr1hh0nz47924-compileobject-player.c/ninvaders.dir/player.c.o -MF /nix/store/mgb2zjqqvx7sslj6q97qr1hh0nz47924-compileobject-player.c/ninvaders.dir/player.c.o.d -o /nix/store/mgb2zjqqvx7sslj6q97qr1hh0nz47924-compileobject-player.c/ninvaders.dir/player.c.o -c /build/source/player.c
copying 0 paths...
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/zzhckm02vyn1dcmibdasvwgc09434hf3-compileobject-ufo.c/ninvaders.dir/ufo.c.o -MF /nix/store/zzhckm02vyn1dcmibdasvwgc09434hf3-compileobject-ufo.c/ninvaders.dir/ufo.c.o.d -o /nix/store/zzhckm02vyn1dcmibdasvwgc09434hf3-compileobject-ufo.c/ninvaders.dir/ufo.c.o -c /build/source/ufo.c
copying 1 paths...
copying path '/nix/store/zzhckm02vyn1dcmibdasvwgc09434hf3-compileobject-ufo.c' from 'ssh://laptop3'...
building '/nix/store/xga02lbklrqlhq6dyvl2n0vqjh9hcjh1-compileobject-view.c.drv' on 'ssh://laptop3'...
copying 0 paths...
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc -std=gnu11 -MD -MT /nix/store/bkycyc4hy0j73lh7n8548ls3037b73f6-compileobject-view.c/ninvaders.dir/view.c.o -MF /nix/store/bkycyc4hy0j73lh7n8548ls3037b73f6-compileobject-view.c/ninvaders.dir/view.c.o.d -o /nix/store/bkycyc4hy0j73lh7n8548ls3037b73f6-compileobject-view.c/ninvaders.dir/view.c.o -c /build/source/view.c
copying 1 paths...
copying path '/nix/store/bkycyc4hy0j73lh7n8548ls3037b73f6-compileobject-view.c' from 'ssh://laptop3'...
building '/nix/store/83phhkx13ww324khm4bippml36dpf62f-ninvaders-0.1.2.drv' on 'ssh://laptop3'...
copying 4 paths...
copying path '/nix/store/bd3gjrq7w6g9n7msswrgbi2863zzczjg-compileobject-highscore.c' to 'ssh://laptop3'...
copying path '/nix/store/hnlgzqvkalh54xnj77dr74qij9g3498w-compileobject-globals.c' to 'ssh://laptop3'...
copying path '/nix/store/hr7fcqp4kfl4lba9kzdjb0cisxx1mgnq-compileobject-nInvaders.c' to 'ssh://laptop3'...
copying path '/nix/store/mgb2zjqqvx7sslj6q97qr1hh0nz47924-compileobject-player.c' to 'ssh://laptop3'...
obj /nix/store/w93jrqj7gsaiqkmnbw0xa2nb8j7r7iga-compileobject-aliens.c
obj /nix/store/hnlgzqvkalh54xnj77dr74qij9g3498w-compileobject-globals.c
obj /nix/store/bd3gjrq7w6g9n7msswrgbi2863zzczjg-compileobject-highscore.c
obj /nix/store/hr7fcqp4kfl4lba9kzdjb0cisxx1mgnq-compileobject-nInvaders.c
obj /nix/store/mgb2zjqqvx7sslj6q97qr1hh0nz47924-compileobject-player.c
obj /nix/store/zzhckm02vyn1dcmibdasvwgc09434hf3-compileobject-ufo.c
obj /nix/store/bkycyc4hy0j73lh7n8548ls3037b73f6-compileobject-view.c
linking ninvaders
/nix/store/s5hkav7whndbfz0szshpb46h4idqdq9a-gcc-wrapper-10.3.0/bin/gcc CMakeFiles/ninvaders.dir/aliens.c.o CMakeFiles/ninvaders.dir/globals.c.o CMakeFiles/ninvaders.dir/highscore.c.o CMakeFiles/ninvaders.dir/nInvaders.c.o CMakeFiles/ninvaders.dir/player.c.o CMakeFiles/ninvaders.dir/ufo.c.o CMakeFiles/ninvaders.dir/view.c.o -o ninvaders /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libncurses.so /nix/store/jzjqfff4cldlm2wpld313a2s1v6r3ycb-ncurses-6.2/lib/libform.so
'ninvaders' -> '/nix/store/377wkpx4qf2dzsar0hjaxfcs5h83cxdn-ninvaders-0.1.2/bin/ninvaders'
copying 1 paths...
copying path '/nix/store/377wkpx4qf2dzsar0hjaxfcs5h83cxdn-ninvaders-0.1.2' from 'ssh://laptop3'...
./result/bin/ninvaders
