use case: qtbase takes 2 hours to compile
the buildPhase is passing, but the installPhase is broken
by caching the result of buildPhase,
i reduce the feedback loop from 2 hours to 2 minutes : )
obvious question: do we have something like this in nix already?
this very much feels like reinventing some wheel …
related: google takes this build-caching even further
by caching every compilation object
edit: i mean the bazel incremental build tool (via ycombinator)
… but one step at a time ; )
full working prototype in
3e50ae7 qt6.qtbase: implement splitBuildInstall, make qtbase build
in the commit, left some comments
to demonstrate how crazy hard this task is with the ninja build tool
short answer: when we run ninja install,
ninja verifies all the build files by mtime and murmurhash64
(hash of build command or hash of output file, not sure),
which all change when we patch the output paths …
challenge: edit the installPhase without causing a rebuild.
currently, i simply copy-paste the installPhase from drv1 to drv2,
modify the installPhase only in drv2, and when it works, move it back to drv1
todo: replace only the basename of /nix/store/hhhh-name
(replace -name with a temporary random hash)
to handle the edge-case, where only the basename appears in the build files
and now …
150 lines sample implementation of the option splitBuildInstall
{ stdenv, cmake }:
splitBuildInstall = true;
buildPhaseResult =
# the original mkDerivation
stdenv.mkDerivation {
pname = "sample";
src = "...";
# this splitBuildInstall implementation works only with cmake
nativeBuildInputs = [ cmake ];
# boilerplate code for splitBuildInstall ...
# ideally should be hidden in stdenv.mkDerivation
# or stdenv.mkDerivationSplitBuildInstall,
# to avoid rebuilding ALL packages
dontInstall = splitBuildInstall;
dontFixup = splitBuildInstall;
# maybe more phases must be disabled
phases = if (!splitBuildInstall) then todoGetTheDefaultPhasesOfMkDerivation
else "${todoGetTheDefaultPhasesOfMkDerivation} splitBuildInstallPhase";
splitBuildInstallPhase = ''
# magic is here :)
# part 1: replace the output paths $out $dev $bin ...
# 1. to fix: error: cycle detected in build
# 2. to use the output paths of the second derivation
echo debug installPhase: copy /build to $out
cp -r /build $out
echo "debug: create empty outputs bin + dev"
# fix: builder failed to produce output path for output 'bin'
mkdir -v $bin $dev
nixStoreEscaped=$(date +%s.%N | sha512sum -)
# v bug in the discourse.nixos.org nix syntax highlighter. wasnt me! :P
nixStoreEscaped=''${nixStoreEscaped:0:11}
echo "debug: nixStoreEscaped = $nixStoreEscaped"
outHash=''${out:11:32}
binHash=''${bin:11:32}
devHash=''${dev:11:32}
echo "debug: store escaped paths in $out/buildPhaseEscapedPaths"
cat >$out/buildPhaseEscapedPaths <<EOF
outHash=$outHash
binHash=$binHash
devHash=$devHash
nixStoreEscaped=$nixStoreEscaped
EOF
# a: /nix/store/a3vjswd3i42xy5hzxras78z0m40g9jk7-qtbase-6.2.0
# b: xxxxxxxxxxxa3vjswd3i42xy5hzxras78z0m40g9jk7-qtbase-6.2.0
# ^ ^ outHash: 32 chars
# ^ nixStoreEscaped: 11 chars
echo "debug: regex = s,/nix/store/($outHash|$binHash|$devHash),$nixStoreEscaped\1,g"
# note: the output paths also appear in binary files = *.so, etc
# so we use the same length as the original path
# tr -d '\0': fix "ignored null byte" when replacing binary files
cd $out
find . -type f | while read f
do
if [ -n "$(sed -i -E "s,/nix/store/($outHash|$binHash|$devHash),$nixStoreEscaped\1,g w /dev/stdout" "$f" | tr -d '\0')" ]
then
# file was replaced
echo "$f" >>$out/patched-files-with-escaped-output-paths.txt
fi
done
echo "debug: replaced install paths in $(wc -l $out/patched-files-with-escaped-output-paths.txt | cut -d' ' -f1) files. see $out/patched-files-with-escaped-output-paths.txt"
if (!splitBuildInstall) then buildPhaseResult
else (buildPhaseResult // stdenv.mkDerivation {
buildInputs = [ buildPhaseResult ]; # not sure if this is needed
inherit (buildPhaseResult) pname version outputs nativeBuildInputs;
# TODO just inherit everything ... override? something more elegant
src = buildPhaseResult.out;
# TODO replace qtbase-everywhere-src-6.2.0 with sourceRoot from buildPhaseResult
unpackPhase = ''
# magic is here :)
# part 2: replace the output paths $out $dev $bin ...
echo "installing from cached build ${buildPhaseResult}"
# this takes about 30 seconds for qtbase. we must copy to get write access
echo "copying cached build files ..."
t1=$(date +%s)
cp -r ${buildPhaseResult}/qtbase-everywhere-src-6.2.0 /build/
echo "copying cached build files done in $(($(date +%s) - $t1)) seconds"
chmod -R +w /build
# set: nixStoreEscaped outHash binHash devHash
source ${buildPhaseResult}/buildPhaseEscapedPaths
outHashNew=''${out:11:32}
binHashNew=''${bin:11:32}
devHashNew=''${dev:11:32}
# replace install paths
echo "replacing output hashes:"
echo " out: $outHash -> $outHashNew"
echo " bin: $binHash -> $binHashNew"
echo " dev: $devHash -> $devHashNew"
cd /build
cat ${buildPhaseResult}/patched-files-with-escaped-output-paths.txt | while read f
do
if [ "$f" = "./env-vars" ]; then continue; fi
if [ ! -e "$f" ]
then
echo "fatal error: no such file: $f"
exit 1
fi
if [ -z "$(
sed -i -E "s,$nixStoreEscaped$outHash,/nix/store/$outHashNew,g w /dev/stdout" "$f" | tr -d '\0'
sed -i -E "s,$nixStoreEscaped$binHash,/nix/store/$binHashNew,g w /dev/stdout" "$f" | tr -d '\0'
sed -i -E "s,$nixStoreEscaped$devHash,/nix/store/$devHashNew,g w /dev/stdout" "$f" | tr -d '\0'
then
echo "fatal error: no paths replaced in $f"
exit 1
fi
done
installPhase = ''
cd /build/qtbase-everywhere-src-6.2.0/build
cmake -P cmake_install.cmake
# "make install" calls "cmake -P ..."
