This guide addresses a common issue with audio crackling and popping in Wine/Proton games on NixOS. The cause is usually Pipewire’s audio buffer size being too small under load.
The solution is to force a larger, more stable minimum quantum size. This introduces a tiny amount of latency (generally unnoticeable in games) but prevents the audio buffer from underrunning.
Here’s the fix:
# /etc/nixos/configuration.nix
# ... other stuff ...
services.pipewire = {
alsa.enable = true;
alsa.support32Bit = true;
pulse.enable = true;
extraConfig = {
pipewire."99-custom-quantum.conf" = {
"context.properties" = {
"default.clock.min-quantum" = 1024;
"default.clock.max-quantum" = 8192;
pipewire-pulse."99-custom-quantum.conf" = {
"pulse.min.quantum" = "1024/48000";
"pulse.default.quantum" = "1024/48000";
"pulse.max.quantum" = "8192/48000";
Hope this saves someone else the headache! Cheers.
