I’m trying to work on my nixos configuration, and am trying to implement an overlay to replace the python sqlalchemy library (currently v2.0.21) with an older version, already packaged as sqlalchemy_1_4. The ‘upgrade’ to 2.0 is known to break many things, so the older version is still available. An application I’m trying to install required the sqlalchemy-migrate library, which is not compatible with sqlalchemy 2.0+. Therefore, I’d like to use an overlay to override this build input.
However, the application is installed through home manager, called as below in my flake.nix:
outputs = inputs@{nixpkgs, home-manager, nixpkgs-stable,...}: let
pkgs = (inputs: {
nixpkgs = {
config = {
allowUnfree = true;
allowBroken = true;
overlays = import ./pkgs/overlays.nix {inherit nixpkgs-stable; pkgs = nixpkgs;};
nixosConfigurations = {
UnknownDevice_ux535 = inputs.nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
pkgs
./nixos/systems/specific/ux535/config.nix
home-manager.users.daniel = import ./home/daniel/home/home.nix;
I’m testing the below overlay just installing python, trying to get the sqlalchemy library to revert to the previous version, but pip freeze
still shows the new version. I’ve tried several variations (not at the same time) to no success.
(self: super: {
self.pythonPackageExtensions = super.pythonPackageExtensions.override {
packageOverrides = pyself: pysuper: {
pyself.sqlalchemy = pysuper.sqlalchemy_1_4;
self: super: {
self.python311Packages = super.python311Packages.overrideAttrs (oldAttrs: {
overrides = pyself: pysuper: {
sqlalchemy = super.sqlalchemy_1_4;
The application I’m trying to install is openlp, for context. I believe that, most likely, the direct sqlalchemy input to the application needs overriding, but also the sqlalchemy input of sqlalchemy-migrate, itself an input. I would have thought it wouldn’t be too much worse than:
self.openlp = super.openlp.override{
sqlalchemy-migrate = super.sqlalchemy-migrate.override{
sqlalchemy=super.sqlalchemy_1_4;
but this doesn’t build, giving the same error as before. Where am I going wrong here?
