Here is my flake: GitHub - refaelsh/dotfiles at 8a72f4fd458b83d1b4b02cb18d4c1fc20735f65c. I am building my NixOS from it.
Recently, I’ve added this: dotfiles/flake.nix at 8a72f4fd458b83d1b4b02cb18d4c1fc20735f65c · refaelsh/dotfiles · GitHub.
Its a flake I am working on my local hard drive - its supposed to configure Xmobar via home-manager module.
But I am getting this error when rebuilding my system:
error: infinite recursion encountered
Please help
You don’t need an additional flake input for it, it’s already present in your flake.
You should be able to add (${inputs.self} + /nixmobar)
or a relative path ../nixmobar
(which is my personal preference) to your imports
in your HM config.
Then you can delete the inner flake.nix
I am sorry @waffle8946, but can I please bother you with concrete changes you are suggesting?
I am afraid I did not understand your answer at all.
I think @waffle8946 means something like this:
description = "NixOS flake";
# with the short url syntax, you don't need "?ref="
# Delete this
# nixmobar.url = "./nixmobar";
outputs = {
and in home-manager/home.nix
# programs.home-manager.enable = true;
home.stateVersion = "24.05";
# home.username = "refaelsh";
# home.homeDirectory = "/home/refaelsh";
imports = [
# Delete this
#inputs.nixmobar.homeModules.nixmobar
# Just import it like your other modules
../nixmobar # uses default.nix
./alacritty.nix
./git.nix
./fzf.nix
./lf.nix
./librewolf.nix
./kitty.nix
./mangohud.nix
./nixmobar.nix
./starship.nix
./termonad.nix
./wezterm.nix
# ./xmobar.nix
./zsh.nix
and then delete the flake.nix
and flake.lock
file in nixmobar/
@railwhale Thats exactly what I did a few days a go while I was developing my module and testing it and etc. Now, I wanna “package” my module as a flake. Thats why I have nixmobar.url = "./nixmobar";
, it is intentional.
No, you want to expose the module as a flake output.
Just add a new entry in your top-level flake.nix
in the outputs
nixosModules.nixmobar = ./nixmobar;
No, you want to expose the module as a flake output .
Yes, you are correct. New terminology, still learning flakes
in the outputs
But I wanna use the output of my new flake Nixmobar.
The way you are suggesting, I will not use the output of my new flake Nixmobar.
If you create a new flake output then you can use inputs.self.nixosModules.nixmobar
Or if it’s an HM module then you can name is homeModules/homeManagerModules.nixmobar (there’s no official naming per the schema for HM).
Thats exactly what I am currently doing. I have this in Nixmpobar’s flake output:
homeModules.nixmobar = import ./default.nix;
And then, I use it like this in my NixOS flake:
inputs =
outputs =
modules = [
But I get the error: infinite recursion encountered
error.
That’s not what I wrote, I said keep it in one flake not two separate ones.
And use inputs.self.homeModules.nixmobar
not a separate flake input.
Also you still haven’t shared the full error, just saying there’s infrec doesn’t tell us much.
But I suggest following my recommendation first, then check if there’s an error, so that we are not chasing an issue that may not need addressing.
Oh! Sorry, I did not understood you. Now I get what you meant. I think. Let me think on it and I get back here asap.
@waffle8946 I did what you are suggesting and now I this error: error: The option home does not exist.
Here are the dotfiles: GitHub - refaelsh/dotfiles at 2bce698c5f28aefa0270fc26d0581d5ddd7fd3d7.
What I did in short is like this (in my NixOS flake):
outputs =
{ self, nixpkgs, ... }@inputs:
homeModules.nixmobar = import ./nixmobar/default.nix;
nixosConfigurations = {
myNixos = nixpkgs.lib.nixosSystem {
specialArgs = {
inherit inputs system;
modules = [
./nixos/configuration.nix
inputs.home-manager.nixosModules.home-manager
./home-manager
This line needs to go in your HM config, not your nixos config.
You are correct. I moved it there, and now I get this error:
error:
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1575:11:
1574| || pred here (elemAt values 1) (head values) then
1575| head values
1576| else
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:821:9:
820| in warnDeprecation opt //
821| { value = addErrorContext "while evaluating the option `${showOption loc}':" value;
822| inherit (res.defsFinal') highestPrio;
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:520:28:
519| addErrorContext (context name)
520| (args.${name} or config._module.args.${name})
521| ) (functionArgs f);
That indicates that you’re trying to use a module arg that was never passed into the module system.
I’m guessing you didn’t add inputs
to extraSpecialArgs
as well?
But --show-trace
should indicate which arg and the location it’s used.
Here is a run with --show-trace
error:
… while calling anonymous lambda
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1571:24:
1570| let f = attrPath:
1571| zipAttrsWith (n: values:
1572| let here = attrPath ++ [n]; in
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1205:18:
1204| mapAttrs
1205| (name: value:
1206| if isAttrs value && cond value
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1208:18:
1207| then recurse (path ++ [ name ]) value
1208| else f (path ++ [ name ]) value);
1209| in
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:254:72:
253| # For definitions that have an associated option
254| declaredConfig = mapAttrsRecursiveCond (v: ! isOption v) (_: v: v.value) options;
255|
… while evaluating the option `system.build.toplevel':
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:836:28:
835| # Process mkMerge and mkIf properties.
836| defs' = concatMap (m:
837| map (value: { inherit (m) file; inherit value; }) (addErrorContext "while evaluating definitions from `${m.file}':" (dischargeProperties m.value))
… while evaluating definitions from `/nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/nixos/modules/system/activation/top-level.nix':
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:837:128:
838| ) defs;
… while calling 'dischargeProperties'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:908:25:
907| */
908| dischargeProperties = def:
909| if def._type or "" == "merge" then
1204| mapAttrs
1205| (name: value:
… from call site
1209| in
255|
… while evaluating the option `assertions':
… while evaluating definitions from `/nix/store/781lg988vxf6dw57igf4l6plm92dfj6c-source/nixos/common.nix':
… from call site
838| ) defs;
907| */
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:914:11:
913| if def.condition then
914| dischargeProperties def.content
915| else
907| */
… from call site
at /nix/store/781lg988vxf6dw57igf4l6plm92dfj6c-source/nixos/common.nix:110:20:
109|
110| assertions = flatten (flip mapAttrsToList cfg.users (user: config:
111| flip map config.assertions (assertion: {
… while calling 'flatten'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/lists.nix:431:13:
430| */
431| flatten = x:
432| if isList x
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/lists.nix:433:21:
432| if isList x
433| then concatMap (y: flatten y) x
434| else [x];
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/lists.nix:433:24:
432| if isList x
434| else [x];
430| */
431| flatten = x:
432| if isList x
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1096:10:
1095| attrs:
1096| map (name: f name attrs.${name}) (attrNames attrs);
1097|
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1096:16:
1095| attrs:
1097|
at /nix/store/781lg988vxf6dw57igf4l6plm92dfj6c-source/nixos/common.nix:110:66:
109|
… from call site
at /nix/store/781lg988vxf6dw57igf4l6plm92dfj6c-source/nixos/common.nix:111:9:
112| inherit (assertion) assertion;
… while calling 'flip'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/trivial.nix:317:16:
316| */
317| flip = f: a: b: f b a;
318|
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/types.nix:577:22:
576| merge = loc: defs:
577| mapAttrs (n: v: v.value) (filterAttrs (n: v: v ? value) (zipAttrsWith (name: defs:
578| (mergeDefinitions (loc ++ [name]) elemType defs).optionalValue
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:858:59:
857| if isDefined then
858| if all (def: type.check def.value) defsFinal then type.merge loc defsFinal
859| else let allInvalid = filter (def: ! type.check def.value) defsFinal;
… while calling 'merge'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/types.nix:881:22:
880| check = x: isAttrs x || isFunction x || path.check x;
881| merge = loc: defs:
882| (base.extendModules {
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:254:28:
255|
… while calling 'mapAttrsRecursiveCond'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/attrsets.nix:1201:5:
1200| f:
1201| set:
1202| let
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:246:33:
245| ({ inherit lib options config specialArgs; } // specialArgs);
246| in mergeModules prefix (reverseList collected);
247|
… while calling 'reverseList'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/lists.nix:1116:17:
1115| */
1116| reverseList = xs:
1117| let l = length xs; in genList (n: elemAt xs (l - n - 1)) l;
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:241:25:
240| merged =
241| let collected = collectModules
242| class
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:457:37:
456|
457| in modulesPath: initialModules: args:
458| filterModules modulesPath (collectStructuredModules unknownModule "" initialModules args);
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:458:7:
459|
… while calling 'filterModules'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:425:36:
424| # modules recursively. It returns the final list of unique-by-key modules
425| filterModules = modulesPath: { disabled, modules }:
426| let
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:451:31:
450| disabledKeys = concatMap ({ file, disabled }: map (moduleKey file) disabled) disabled;
451| keyFilter = filter (attrs: ! elem attrs.key disabledKeys);
452| in map (attrs: attrs.module) (genericClosure {
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:412:22:
411| let
412| module = checkModule (loadModule args parentFile "${parentKey}:anon-${toString n}" x);
413| collectedImports = collectStructuredModules module._file module.key module.imports args;
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:371:11:
370| then
371| m:
372| if m._class != null -> m._class == class
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:412:35:
411| let
… while calling 'loadModule'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:348:53:
347| # Like unifyModuleSyntax, but also imports paths and calls functions if necessary
348| loadModule = args: fallbackFile: fallbackKey: m:
349| if isFunction m then
… from call site
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:349:12:
350| unifyModuleSyntax fallbackFile fallbackKey (applyModuleArgs fallbackKey m args)
… while calling 'isFunction'
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/trivial.nix:991:16:
990| */
991| isFunction = f: builtins.isFunction f ||
992| (f ? __functor && isFunction (f.__functor f));
at /nix/store/fpivx4sjcp2vk4rp9nhliln5cwcp3kc6-source/lib/modules.nix:518:35:
517| context = name: ''while evaluating the module argument `${name}' in "${key}":'';
518| extraArgs = mapAttrs (name: _:
… while evaluating the module argument `inputs' in ":anon-5:anon-1":
I have no idea what am I looking at here. Please help
Where should I add extraSpecialArgs
please?
In home-manager/default.nix
, like this:
# Add inputs to module args
{ inputs, nixmobar, ... }:
home-manager = {
extraSpecialArgs = {
inherit inputs;
users.refaelsh = import ./home.nix;
This worked. Thank you very much.
2 questions please:
- How did you know to arrive from
to extraSpecialArgs
- I tried having the module be an output of the Nixmobar flake and use it as input in my NixOS flake, as per the original question, but now I am getting this error:
error: attribute 'nixmobar' missing
at /nix/store/4a0nc9r1hkrg6wvqm8f73yv43742s550-source/home-manager/home.nix:16:5:
15| # inputs.self.homeModules.nixmobar
16| inputs.nixmobar.homeModules.nixmobar
17| ./alacritty.nix
The current state of the dotfiles is here: GitHub - refaelsh/dotfiles at 11797fcac49d834db0037b463bff39d390470464.
