How to help cleaning up issues?
Related to Suggest closing issue - Help - NixOS Discourse
I would like to help cleaning of now irrelevant issues like steampipe doesn't start · Issue #215945 · NixOS/nixpkgs · GitHub
The bot already put a stale label, would it be possible to allow people to ask the bot for closure ?
Regards
That’s a pointless task, just close it if it’s irrelevant. Anyone in the NixOS org (i.e. any maintainer) can do so.
Well that’s the point, I’m not a maintainer as I’m waiting since June to have my first PR merged so in the mean time I want to help triage issues
You can adopt any package that you want to maintain.
Really, maintaining packages is far more helpful for nixpkgs than being an issue close bot.
I know, as stated, it’s been 5 months since my PR is open. That is me wanting to adopt and maintain a package. Since I can’t do anything beside waiting I simply wanted to help with triage.
Again, issue triage is not really a valueable task in nixpkgs, it’s just busywork that has a decent likelihood of just pissing off the issue author if you close it without verifying that the issue is no longer present. Unless you are doing that, in which case you can just comment that it should be closed and get the author to respond. People are way too itchy to use the stale bot and it makes no sense tbqh.
Our bottleneck is mostly PR review and merging (as you found) and orphaned packages. So if you have a contentious PR and still want to join the NixOS org, you’re better off finding another package that you want to maintain and adopting it directly.
Looks like the issue got closed, so that’s progress I suppose.
@ZeikoFr : If you have a PR needing review, try posting it in https://discourse.nixos.org/t/prs-ready-for-review/ . Feel free to DM if you need some help with next steps, I might be able to help (no promises, unfortunately!).
