Hello all,
I’m new to Nix, so I am likely doing something wrong, but allow me to articulate what the issue is.
I am using rules_nixpkgs, to try and install a number of Torch related packages and make them available to my Bazel build environment. Specifically, I would like all of them to depend on torch-bin
, rather than torch
, since this actually has CUDA support.
My initial attempt was this:
nixpkgs_python_configure(
repository = “@nixpkgs”,
python3_attribute_path = “”"
python310.withPackages(ps: with ps; [
torch-bin
(detectron2.override { torch = python310.pkgs.torch-bin; })
(optuna.override { torch = python310.pkgs.torch-bin; })
(pytorch-lightning.override { torch = python310.pkgs.torch-bin; })
(torchmetrics.override { torch = python310.pkgs.torch-bin; })
(torchvision.override { torch = python310.pkgs.torch-bin; })
(torchaudio.override { torch = python310.pkgs.torch-bin; })])
However, this resulted in conflicts.
I then tried something a little more sophisticated (which I am unsure if correct or not):
(python310.pkgs.override {
overrides = self: super: {
})detectron2 optuna torchvision torchmetrics torchaudio pytorch-lightning
This completes without error, however it seems that torch
is still being used. The reason I know this is because torch cannot see my GPUs:
In [4]: torch.cuda.is_available()
Out[4]: False
But, if I add torch-bin to the list of things to install, I get these errors:
building ‘/nix/store/iysal0lz3hs1xyi45niwsq94i6iaw8aa-python3-3.10.13-env.drv’…
error: collision between/nix/store/5iprrznhmw6ma6fgkgvjr37cmvinmvr7-python3.10-torch-2.0.1/lib/python3.10/site-packages/torchgen/dest/__pycache__/register_dispatch_key.cpython-310.pyc' and
/nix/store/55ivn06v4xr0hkvdxif743x23fwcz7lc-python3.10-torch-2.0.1/lib/python3.10/site-packages/torchgen/dest/pycache/register_dispatch_key.cpython-310.pyc’
error: builder for ‘/nix/store/iysal0lz3hs1xyi45niwsq94i6iaw8aa-python3-3.10.13-env.drv’ failed with exit code 255
However, removing all other packages and just installing torch-bin
succeeds, and torch sees my GPUs as available:
In [1]: import torch
In [2]: torch.cuda.is_available()
Out[2]: True
Any ideas? I’m using Ubuntu 22.04 in WSL, with nix version 2.18.1 with the 23.11 package set.
