I am trying to work through a final set of changes to get VM instances fully supported on LXD. Unfortunately there are a number of changes, so I’ve tried to break it up into smaller pieces for review. If you’re interested in pairing with me on these changes let me know.
https://github.com/NixOS/nixpkgs/pull/248395
https://github.com/NixOS/nixpkgs/pull/248398
https://github.com/NixOS/nixpkgs/pull/248406
theduke
August 13, 2023, 8:19pm
2537
https://github.com/NixOS/nixpkgs/pull/248948
Mainly posting because a previous PR from 0.1.7 to 0.1.8 was ignored for a month.
bouk
August 14, 2023, 12:37pm
2538
https://github.com/NixOS/nixpkgs/pull/218783
This one has been left hanging for a while, but it fixes an important bug in Rust crate builds on macOS.
A small, hopefully non-controversial extension to buildEnv
that’s been sitting there for quite a while. It would be very useful for texlive.
https://github.com/NixOS/nixpkgs/pull/225184
romildo
August 15, 2023, 10:22am
2544
Catouc
August 15, 2023, 8:39pm
2548
Majiir
August 16, 2023, 2:19am
2550
Looking for a Python reviewer for this update:
https://github.com/NixOS/nixpkgs/pull/247618
Still looking for a systemd reviewer for this initrd fix:
https://github.com/NixOS/nixpkgs/pull/209964
Adding a new major version of Teleport.
NixOS:master
← justinas:teleport-13
opened 06:07PM - 05 Jul 23 UTC
###### Description of changes
New major version.
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] Tested, as applicable:
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
- [x] (Package updates) Added a release notes entry if the change is major or breaking
bbigras
August 17, 2023, 4:23am
2554
