i will open pr for packaging SDK / Selenium Webdriver using AT-SPI · GitLab after this i didn’t done it in this pr because i might need to force push and i am not sure to force push to older commit
https://github.com/NixOS/nixpkgs/pull/250039
beef
August 19, 2023, 3:55am
2564
sikmir
August 19, 2023, 12:27pm
2566
chvp
August 19, 2023, 1:46pm
2567
mmlb
August 20, 2023, 11:47pm
2569
h7x4
August 21, 2023, 8:09am
2571
https://github.com/NixOS/nixpkgs/pull/249610
NixOS:master ← mdarocha:openra-playtest
opened 06:44AM - 16 Aug 23 UTC
## Description of changes
https://github.com/OpenRA/OpenRA/releases/tag/playt… est-20230808
https://github.com/OpenRA/OpenRA/releases/tag/playtest-20230927
Adding a new package since `playtest` is a different release channel.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] Tested, as applicable:
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
Thanks a lot if you do!
chvp
August 22, 2023, 2:56pm
2576
zendo
August 22, 2023, 4:22pm
2577
baduhai
August 23, 2023, 12:26am
2578
Has been packaged by one maintainer and reviewed by me, the other maintainer
https://github.com/NixOS/nixpkgs/pull/248486
(I’m still waiting for some kind of auto-merge when the maintainers approve… And even more weirdly, I can’t approve the PR )
nat
August 23, 2023, 10:02pm
2582
