peeley
September 5, 2023, 5:08pm
2628
jsoo1
September 5, 2023, 6:03pm
2629
pjjw
September 6, 2023, 6:21pm
2631
hey there- would love to get this landed and stop carrying my own derivation around for it:
https://github.com/NixOS/nixpkgs/pull/250018
azuwis
September 7, 2023, 2:42pm
2634
chivay
September 8, 2023, 11:22am
2637
fugi
September 8, 2023, 11:51am
2638
Igir, a ROM manager, javascript stuff, it’s a simple derivation with a patchShebangs somewhere.
https://github.com/NixOS/nixpkgs/pull/252765
trrntzip, a TorrentZip implementation, simple mkDerivation.
https://github.com/NixOS/nixpkgs/pull/253132
alois31
September 9, 2023, 2:17pm
2641
traxys
September 10, 2023, 4:16pm
2643
Fit-trackee, a viewer for GPX traces
NixOS:master
← traxys:fit-trackee
opened 07:36PM - 23 Apr 23 UTC
###### Description of changes
[FitTrackee](https://samr1.github.io/FitTrackee… /) is a web application to track your outdoor activities (workouts) from gpx files and keep your data on your own server.
To package it I had to package a number of its dependencies.
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] Tested, as applicable:
- [23.05 Release Notes (or backporting 22.11 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
Thanks a lot if you do!
justinas
September 10, 2023, 5:53pm
2644
Adding a new major version of teleport. Would be great to merge this before v14 arrives later this month.
NixOS:master
← justinas:teleport-13
opened 06:07PM - 05 Jul 23 UTC
New major version.
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
- [x] (Package updates) Added a release notes entry if the change is major or breaking
mzabani
September 11, 2023, 7:25pm
2646
My first PR to nixpkgs. It fixes ignored attrsets for cloudflare tunnel configs, improves docs slightly and removes one documented but not implemented feature.
NixOS:master
← mzabani:fix-cloudflare-tunnel-ignored-attrs
opened 10:27PM - 07 Jun 23 UTC
This PR:
- Fixes the fact that the `originRe… quest` attrset was previously ignored.
- Documents that credentialsPath needs to be accessible to the right user, even if it might be obvious to most
- Removes warp-routing as it was apparently unused (and I don't know how to implement it). Please double-check that I'm not missing something here.
Question to reviewers as this is my first contribution to nixpkgs: should this be backported to 23.05? It's a fix, but it can make nixos-rebuild fail if someone was using one of these attrsets, even if they had no effect in practice.
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [23.11 Release Notes (or backporting 23.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
