Enable cross-compilation for qbe, harec and hare
NixOS:master β onemoresuza:hare-crosscomp
opened 04:36PM - 01 Mar 24 UTC
## Description of changes
- **qbe: enable cross-compilation**
- **harec: ena⦠ble cross-compilation**
- **hare: enable cross-compilation**
## Things done
- Built on platform(s)
- [X] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [X] Tested, as applicable:
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
## Note for reviewers
To test this PR:
```bash
git clone --filter=blob:none --depth=1 -b hare-crosscomp https://github.com/onemoresuza/nixpkgs.git hare-crosscomp
cd hare-crosscomp
nix-build -E '
pkgs = import ./. {};
x86_64 = builtins.attrValues {
inherit (pkgs.pkgsCross.gnu64) qbe harec hare;
aarch64 = builtins.attrValues {
inherit (pkgs.pkgsCross.aarch64-multiplatform) qbe harec hare;
aarch64 ++ x86_64
Thanks a lot if you do!
Enable parallel building and fix tests on darwin for qbe
NixOS:master β onemoresuza:qbe-darwin-test-fix
opened 09:15PM - 01 Mar 24 UTC
- Fix the tests on darwin because of `/tmp` being har⦠dcode.
- Enable parallel building
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review rev HEAD"`. Note: all changes have to be committed, also see [nixpkgs-review usage](https://github.com/Mic92/nixpkgs-review#usage)
NixOS:master β pca006132:llvm-bolt
opened 06:17PM - 17 Feb 24 UTC
adds llvm-bolt for llvm 17.
Closes #176536. Note⦠that we need quite a large patch, we probably want to upstream some changes to allow bolt standalone build.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested, as applicable:
No activities for 2 weeks. I understand this is a lot to review but it will be better if there is some feedback or timeline.
Update to a minor python package, ty in advance :
NixOS:master β stalkerhumanoid:update-mediafile-0.12.0
opened 04:11PM - 24 Feb 24 UTC
Updated from 0.10.1 to 0.12.0
[Mediafile changelog:]β¦ (https://mediafile.readthedocs.io/en/latest/#)
> v0.12.0
Add the multiple-valued properties artists_credit, artists_sort, albumartists_credit, and albumartists_sort.
v0.11.0
List-valued properties now return None instead of an empty list when the underlying tags are missing altogether.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This is ready for a merge:
NixOS:master β nviets:xgboost203
opened 03:11AM - 26 Feb 24 UTC
Updating xgboost to 2.0.3
## Things done
β¦ - Built on platform(s)
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Hi, would appreciate a review. Thanks in advance.
NixOS:master β evan-goode:evan-goode/pollymc
opened 05:06AM - 29 Nov 23 UTC
[PollyMC](https://github.com/fn2006/PollyMC) is a l⦠ibre [Minecraft](https://minecraft.net) launcher and a fork of [Prism Launcher](https://github.com/PrismLauncher/PrismLauncher) that:
- Removes the DRM to allow use without a Microsoft account
- Adds support for alternative Minecraft API servers, such as [Ely.by](https://github.com/elyby)
- Adds back the ability to download FTB modpacks from within the launcher
- Adds back support for Mojang accounts (though online-mode servers still won't work with Mojang accounts)
**PollyMC** (two Ls) is NOT AFFILIATED with **PolyMC** (one L). The project originated as a fork of PolyMC, hence the name.
I'll also note that while PollyMC allows users to play Minecraft without verifying that they have a license from Mojang, it is GPLv3 software and does not distribute any of the game's proprietary files. The game itself is downloaded directly from Mojang's servers at runtime, exactly like Prism Launcher.
## Things done
Builds on macOS or aarch64 have not been tested, but this derivation is almost identical to Prism Launcher, which is already in nixpkgs.
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [23.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) (or backporting [23.05 Release notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md))
### Priorities
This has two approvals but seems to be stuck waiting on a third reviewer for a month. Any chance it could be un-stuck?
Just package version bumps, already built and tested for all default systems (which takes significant time because PRs target staging):
NixOS:staging β matshch:bump-expat
opened 09:50PM - 29 Feb 24 UTC
Changes: https://github.com/libexpat/libexpat/blob/R_β¦ 2_6_1/expat/Changes
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [x] `sandbox = true`
- [x] Tested, as applicable:
NixOS:staging β matshch:bump-s2n-tls
opened 12:33PM - 15 Feb 24 UTC
- https://github.com/aws/s2n-tls/releases/tag/v1.4.4
β¦
- https://github.com/aws/s2n-tls/releases/tag/v1.4.5
The most interesting change is aws/s2n-tls#4352, which fixes the issue NixOS/nix#5947.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
pawsen
March 3, 2024, 1:06pm
3568
Iβve got a trivial fix to make openscad properly wrapped so that it works in unpolluted environments. I think this is an easy one so hopefully nobody minds me soliciting a quick look here in this thread.
NixOS:master β pawsen:openscad_gsettings_fix
opened 01:03PM - 03 Mar 24 UTC
This app needs the wrapGAppsHook so that the GLib schemas are available at runti⦠me, otherwise it will crash when a file dialog is invoked in an unpolluted environment.
Fixes the GSettings errors
GLib-GIO-ERROR **: No GSettings schemas are installed on the system (openscad:26805): GLib-GIO-ERROR **: 13:10:37.913: Settings schema 'org.gtk.Settings.FileChooser' is not installed
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Auto-update wasnβt quite sufficient. Iβm the only maintainer for the package, so I canβt ask any co-maintainers to have a look at it:
NixOS:master β iFreilicht:update-persepolis
opened 05:49PM - 02 Mar 24 UTC
Closes #288825
Major version update from 3.2.0β¦ to 4.0.0.
Auto-update didn't work because one patch didn't apply. Additionally, I could remove one patch, as it has been merged upstream.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
