NixOS:master β rafaelrc7:stremio/missing-dependencies
opened 12:03AM - 20 Feb 24 UTC
## Description of changes
For package updates please link to a changelo⦠g or describe changes, this helps your fellow maintainers discover breaking updates.
Stremio depends on `ffmpeg` for features such as streaming to a chromecast. Without `ffmpeg`, when trying to stream to a chromecast, it never loads, when adding ffmpeg to `PATH` (for example in an ad-hoc nix shell), the feature works fine.
So, this PR wraps the derivation executable with `ffmpeg` binaries added to `PATH`.
This dependency can also be confirmed by seeing some of the official build scripts, that list both the `ffmpeg` and `ffprobe` (the latter is also included in the `ffmpeg` package) binaries:
- [AppImage](https://github.com/Stremio/stremio-shell/blob/b7f862e1fb89744c5c54ae81e5dd87ff81cab967/AppImage.makefile#L19-L20)
- [Windows](https://github.com/Stremio/stremio-shell/blob/b7f862e1fb89744c5c54ae81e5dd87ff81cab967/build_windows.bat#L34-L35)
- [Arch Linux](https://github.com/Stremio/stremio-shell/blob/b7f862e1fb89744c5c54ae81e5dd87ff81cab967/distros/ArchLinux/PKGBUILD#L11)
I also split the derivation arguments into multiple lines, as the list was already pretty long, and I had to add a new dependency.
Another missing dependency seems to be `openssl`. However, when searching the code, it seems only to be used for the autoupdate feature, which will not be useful in the nix package, so I believe it would be fine to not include it.
- [autoupdater.cpp](https://github.com/Stremio/stremio-shell/blob/b7f862e1fb89744c5c54ae81e5dd87ff81cab967/autoupdater.cpp#L9)
- [verifysig.c](https://github.com/Stremio/stremio-shell/blob/b7f862e1fb89744c5c54ae81e5dd87ff81cab967/verifysig.c#L5)
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
Adding a missing dependency to stremio, required for streaming to chromecasts
NixOS:master β outfoxxed:acpid
opened 11:44AM - 31 Dec 23 UTC
Adds initrd/stage1 support to the acpid module. Als⦠o pretty much a complete refactor.
## Things done
Tested stage1 and stage2 support in personal configurations using `powerEventCommands` and `handlers`.
##### (self) Reviewed points
- [x] changes are backward compatible
- [x] (N/A) removed options are declared with `mkRemovedOptionModule`
- [x] (N/A) changes that are not backward compatible are documented in release notes
- [x] (N/A) module tests succeed on ARCHITECTURE
- [x] options types are appropriate
- [x] options description is set
- [x] options example is provided
- [x] documentation affected by the changes is updated
Bringing this up again, got some review in January but no responses.
You might want to post that one over on the PRs already reviewed thread.
hennk
March 16, 2024, 8:23am
3638
NixOS:master β hennk:poetry-plugin-poeblix
opened 05:24PM - 13 Mar 24 UTC
https://github.com/spoorn/poeblix
## Things doneβ¦
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This adds a plugin for the poetry python dependency manager, which allows to export python wheel files using the exact locked dependencies as saved with poetry
Useful to anyone that needs to log time and generate invoices!
NixOS:master β Sleepful:add-pkg-kimai
opened 02:57AM - 15 Mar 24 UTC
Adds Kimai package and module for NixOS
Kimai is a time-tracking app for free⦠lancers and enterprises, offers many configurations. I have been using it for a while in my NixOS instance and I figured it was time I contribute it back here.
I am contributing the release I have been using:
https://github.com/kimai/kimai/releases/tag/2.10.0
The tool [composer2nix](https://github.com/svanderburg/composer2nix) was used to some extent to generate some of the nix files for the php package.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
- [ ] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md). --> I hope so!
melvyn2
March 16, 2024, 8:51pm
3643
NixOS:master β tcheronneau:issue-288907
opened 12:24PM - 15 Feb 24 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
Super simple one line fix
Anyone with an Optimus hybrid laptop?
NixOS:release-23.11 β abmantis:fix_bumblebee_xf86mouse
opened 05:12PM - 21 Jan 24 UTC
Without this the X11 server would fail to start with β¦ the error:
```(EE) Failed to load module "mouse" (module does not exist, 0)```
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
My first package contribution, a simple zsh plugin
NixOS:master β fidgetingbits:add-zsh-zhooks-plugin
opened 03:20AM - 17 Mar 24 UTC
Add myself to maintainers list and add a new simple⦠zsh plugin as my first package.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [x] `sandbox = true`
Small tree-sitter grammar addition
NixOS:master β fidgetingbits:add-tree-sitter-talon
opened 07:49AM - 17 Mar 24 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
