~~https://github.com/NixOS/nixpkgs/pull/102573~~
A Forth compiler!
https://github.com/NixOS/nixpkgs/pull/100635
I’ve been using this for a number of weeks without any issues.
Add a Java runtime environment to the makemkv wrapper, since JRE is required for certain Blu-Rays:
https://github.com/NixOS/nixpkgs/pull/103085
Fix a gcc ICE on AArch64:
https://github.com/NixOS/nixpkgs/pull/102518
Simple version bump of Huggingface tokenizers:
https://github.com/NixOS/nixpkgs/pull/97335
https://github.com/NixOS/nixpkgs/pull/101176
https://github.com/NixOS/nixpkgs/pull/99226
https://github.com/NixOS/nixpkgs/pull/98633
https://github.com/NixOS/nixpkgs/pull/91723
https://github.com/NixOS/nixpkgs/pull/102753
https://github.com/NixOS/nixpkgs/pull/102378
https://github.com/NixOS/nixpkgs/pull/98234
https://github.com/NixOS/nixpkgs/pull/98212
https://github.com/NixOS/nixpkgs/pull/102282
Would appreciate if go-ethereum: 1.9.23 -> 1.9.24 by RaghavSood · Pull Request #103653 · NixOS/nixpkgs · GitHub could get looked at, contains a fix for a consensus issue as well as a DoS.
https://github.com/NixOS/nixpkgs/pull/83904
This fixes a fairly critical issue with the sanoid module, but has been sitting for a long time without anyone who can merge reviewing it.
inkcut includes inkscape plugin code so you can invoke it straight from inkscape.
This PR makes it possible to install inkscape with inkcut and the relevant plugin in one go:
Fedora backgrounds for your favorite distribution:
https://github.com/NixOS/nixpkgs/pull/103622
Boring bump of a spaCy dependency:
Trivial update for GEM (graphics library for PureData) means we no longer have to patch it:
