https://github.com/NixOS/nixpkgs/pull/100531
I am not pushing anyone, but I want to add a couple more packages and mark myself as a maintainer. Therefore they are dependent on my first commit in the nixpkgs. If there is another right way to achieve that (e.g. separate PR with just maintainers list change or add all packages in the same PR) - please, tell me.
- nixos/security.gnupg: provisioning GnuPG-protected secrets through the Nix store
nixos/security.gnupg: provisioning GnuPG-protected secrets through the Nix store by ju1m · Pull Request #93659 · NixOS/nixpkgs · GitHub - nixos/tor: improve type-checking and hardening
nixos/tor: improve type-checking and hardening by ju1m · Pull Request #97740 · NixOS/nixpkgs · GitHub - nixos/syncoid: split in multiple systemd services and harden them
nixos/syncoid: split in multiple systemd services and harden them by ju1m · Pull Request #98455 · NixOS/nixpkgs · GitHub - zerobin: update to v1.0.5
zerobin: update to v1.0.5 by ju1m · Pull Request #98734 · NixOS/nixpkgs · GitHub - Update public-inbox to 1.6.0 and add systemd services
Update public-inbox to 1.8.0 and add systemd services by ju1m · Pull Request #104457 · NixOS/nixpkgs · GitHub - Add freeciv service
Add freeciv service by ju1m · Pull Request #104460 · NixOS/nixpkgs · GitHub
Small change to add xz to PATH for amazon-init.
https://github.com/NixOS/nixpkgs/pull/85244
Here’s a Nix PR (instead of a nixpkgs one):
This package has been reviewed and (I believe) all comments have been addressed, but the original reviewer has gone awol, would be super happy if someone would take a look at it:
Update for easy-rsa:
Adding nixos-rebuild switch --switch-generation:
keystore-explorer:
This is a fairly large one, a rework of androidenv to change how Android repo data was being stored and fetched and how licenses were being accepted. Seems like several developers are testing it out successfully to build their Android projects at this point.
Update: merged
Added support for classifier to fetchMavenArtifact.
Should be a fairly simple PR, a very similar package was added in september.
This one includes some changes in the NixOS module and handling of secrets, which could use a second opinion:
https://github.com/NixOS/nixpkgs/pull/105369
