This will fix that nifty new System Monitor GNOME Extension!
NixOS:master
← Nanotwerp:gnome-system-monitor-extension-fix
opened 03:55PM - 08 May 24 UTC
## Description of changes
This PR patches `gnomeExtensions.system-monitor`, an … extension installed by default as of `GNOME 46`, so that `GTop` is within its path; otherwise, an error occurs when trying to enable this extension.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
Bump. These patches fix issues with Proxmox LXC and VM images. Can someone please review?
Bump, I need this so I can package, another package
mi-ael
May 9, 2024, 5:38pm
3909
NixOS:master
← mi-ael:init-openvas-smb
opened 06:25PM - 02 May 24 UTC
SMB module for Greenbone Community Edition
https:/… /github.com/greenbone/openvas-smb
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] `sandbox = true`
After this is merged, I’m gonna package more openvas-* stuff
Hey there! I have had a PR to add the filebrowser service to nixpkgs sitting a couple weeks now. Anyone wanna take a look at it?
NixOS:master
← sdellysse:filebrowser-service
opened 07:04PM - 24 Apr 24 UTC
Added service configuration for filebrowser. I'm op… en to suggestions on how to better structure the options since this application is primarily configured through a mutable single-file database.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested, as applicable:
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
Merging vmagent into code of victoriametrics as they have the same source base, but a metrics pushing client still dont want to have the full server installed, it keeps the vmagent package.
Should be non breaking and i am using that in my infra since pr creation.
NixOS:master
← Shawn8901:migrate_vmagent
opened 01:12PM - 01 May 24 UTC
fixes #306253
Main goal is to avoid having 2 de… finitions for building for the same repository (see linked issue).
This PR migrates the building of the client tool vmagent to the victoriametrics package.
This deduplicates the code base on our side as upstream is maintaining and building everything from the same code base (so its a mono repo with different subpackages).
Beside just to split out vmagent, i tried to build up all logical packages that make sense to me, to that people can override the package easily to optimize the derivation size if needed.
One has now
1. the timeseries server
2. vmagent as pushing service
3. alterting tools
4. vmauth as HTTP proxy in case one wants to use authentication for the timeseries server
5. the backup tools to backup the timeseries
6. vmctl which is used to migrate between timeseries (vm to vm, but also from other servers to vm)
7. logging server
A pure minimal server then could just enable the `withServer` and disable everything else.
I personally switched my VM server for testing to just use `withServer` and `withVmAuth` (and `withVmAgent` to be able to push metrics to itself), beside that every other thing is disabled as i am not using it and it seems to run fine.
The said package is ~76MiB large.
The full package victoriametrics is about 162 MiB.
Vmagent by itself is be about 53 MiB (which we are migrating here and is about the same like the old).
I did check the functionality of the reduces package by looking at logs and verifying that my Grafana (with vm-datasource installed) is still able to query the data.
Vmagent is deployed to all my machines, checked the log on those also.
As the vmagent package had different maintainers listed, i migrated everyone to the victoriametrics package.
Please let me know if you disagree with that action @NULLx76 @leona-ya
As the action should be transparent for user of the vmagent package, i dont see a requirement to create a release note here.
In addition, i also added myself as a maintainer.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
Elysa
May 11, 2024, 6:19pm
3917
NixOS:master
← ElysaSrc:master
opened 03:44PM - 17 Mar 24 UTC
Adding package `catppuccin-sddm` on nixpkgs, since … we already have some other catppuccin official themes (gtk, plasma, icons etc...).
I've added options to the derivation to control the theme file (flavor, theme.conf options...).
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
Hello, I already shared this one in the past hope it’s okay to share it again.
Since this, I’ve modified the PR to fit RFC 140 and it has been reviewed by upstream’s author.
