NixOS:master
← rvl:libadwaita-fix-split-outputs
opened 12:56AM - 11 Feb 24 UTC
## Description of changes
Previously, only `bin/adwaita-1-demo` was split to …the `libadwaita.devdoc` output.
The demo also has a launcher, icon, etc, which were polluting `libadwaita.out`.
This PR makes it fully move demo files to `devdoc` output.
cc @dotlambda
## Things done
- [ ] Built on platform: x86_64-linux
- [ ] Tested, as applicable:
- [x] N/A [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
