NixOS:master
← commiterate:update/sonar-scanner-cli
opened 12:47AM - 25 Jul 24 UTC
## Description of changes
For package updates please link to a changelo…g or describe changes, this helps your fellow maintainers discover breaking updates.
* Update `sonar-scanner-cli` from 4.7.0.2747 ([release](https://github.com/SonarSource/sonar-scanner-cli/releases/tag/4.7.0.2747)) → 6.1.0.4477 ([release](https://github.com/SonarSource/sonar-scanner-cli/releases/tag/6.1.0.4477)).
* Change from pre-built binaries to source build using `maven.buildMavenPackage` ([docs](https://nixos.org/manual/nixpkgs/unstable/#maven-buildmavenpackage)).
* Options for `maven.buildMavenPackage` are based on the [`ktfmt` Nix package](https://github.com/NixOS/nixpkgs/tree/18c8da898c60e1e4a3612cd22137f255b1d87cca/pkgs/by-name/kt/ktfmt) and [`h2` Nix package](https://github.com/NixOS/nixpkgs/tree/18c8da898c60e1e4a3612cd22137f255b1d87cca/pkgs/by-name/h2/h2).
* Add support for aarch64 Linux + macOS (Darwin).
* Closes https://github.com/NixOS/nixpkgs/issues/328044.
* Fix license from GPL-3.0 to LGPL-3.0.
* Make auto-upgradable by `nix-update`.
* ~~The `pom.xml` patch throws in some potential wrenches. Currently asking upstream to lock these instead of us patching it in as it's mutually beneficial (https://github.com/SonarSource/sonar-scanner-cli/pull/185).~~
* Plugin versions are locked by the parent POM.
* Migrate from category hierarchy to name-based package directories (`pkgs/by-name`).
`sonar-scanner-cli` uses `maven-assembly-plugin` which produces a `{repository}/target/sonar-scanner-${project.version}.zip` that has the following contents:
```text
├── bin
│ ├── sonar-scanner
│ ├── sonar-scanner-debug
│ ├── sonar-scanner-debug.bat
│ └── sonar-scanner.bat
├── conf
│ └── sonar-scanner.properties
└── lib
└── sonar-scanner-cli-6.1-SNAPSHOT.jar
The new build-from-source strategy just does a Maven build then unzips this directory into `$out`.
I couldn't find a way to make `unzip` do something like "Extract here" so I need to unzip to `target/sonar-scanner-${version}` then move the files into `$out`.
Basic build + functionality testing:
```shell
% nix-build -A sonar-scanner-cli
/nix/store/cmz860kfmi7x0ks3yqd7a1ibpmxjdfhm-sonar-scanner-cli-6.1.0.4477
% /nix/store/cmz860kfmi7x0ks3yqd7a1ibpmxjdfhm-sonar-scanner-cli-6.1.0.4477/bin/sonar-scanner --help
usage: sonar-scanner [options]
Options:
-D,--define <arg> Define property
-h,--help Display help information
-v,--version Display version information
-X,--debug Produce execution debug output
% /nix/store/cmz860kfmi7x0ks3yqd7a1ibpmxjdfhm-sonar-scanner-cli-6.1.0.4477/bin/sonar-scanner-debug --help
Executing SonarScanner CLI in Debug Mode
SONAR_SCANNER_DEBUG_OPTS="-Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=8000"
SONAR_SCANNER_JAVA_OPTS=" -Xdebug -Xrunjdwp:transport=dt_socket,server=y,suspend=y,address=8001"
Listening for transport dt_socket at address: 8000
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [ ] `sandbox = relaxed`
- [x] `sandbox = true`
- [x] Tested, as applicable:
Thanks a lot if you do!
###### Maintainer pings
@peterromfeldhk
