phaer
September 5, 2024, 2:16pm
4521
A rather big, but hopefully not too complicated module PR to have just one diskSize option in virtualisation and not >10.
NixOS:master ← phaer:virtualisation-diskSize
opened 12:54PM - 04 Sep 24 UTC
## Description of changes
There's currently a variety of `diskSize` options d… eclared in `nixpkgs`, which all allow to specify a disk size in megabytes while some also allow a magic `auto` value.
This PR aims to start de-duplicating as many as those options as feasible.
To do so, we introduce a new `virtualisation-options.nix` file which offers modules for shared options. While `diskSize` is the first one, it probably won't be the last. Things like memory size, desired free space in a disk image, etc could be shared in future PRs.
`virtualisation.diskSize` was already defined in `qemu-vm.nix`. Since setting this to `null` was disallowed in https://github.com/NixOS/nixpkgs/pull/338967, it's more compatible with other diskSize declaration in nixpkgs. The remaining difference is that most modules using diskSize support `auto` because they just end up passing it to `make-disk-image.nix`, but qemu and oci-image doe not. We therefore declare an internal `diskSizeAutoSupported` option which we set to false where `auto` is not supported.
I explicitly opted for an `assertion` instead of widening the enum type, as I think UX is better that way if you just set `virtualisation.diskSize` once to build several image formats and then add a module which does not support `auto`. In the latter case you'd get a type error, here you get the message of the assertion.
To de-duplicate those options might be a good start to standardize a few of our config options between various virtualization solutions. Doing so might hopefully lower required maintenance work and lower to barrier to build more complex functionality that works the same for different image builders & virtual machine runners.
nixfmt-rfc-style changes are all in the first commit, for easier reviews.
I built the following images succesfully but haven't been able to live test them on their respective platforms. I also haven't tested darwinBuilder yet.
* digitalOceanImage
* googleComputeImage
* linodeImage
* azureImage
* amazonImage
* openstackImage
* virtualBoxOVA
* hypervImage
* VMA # proxmoxImage
* OCIImage
* ~~brightboxImage~~ broken on master as well, see https://github.com/NixOS/nixpkgs/pull/339790
## Things done
- Built on platform(s)
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
This PR is quite small. It adds a new terminal emulator (zutty), similar to xterm etc.:
NixOS:master ← rolfschr:zutty
opened 04:56AM - 21 Aug 24 UTC
This PR adds [zutty](https://tomscii.sig7.se/zutty/… ), a terminal emulator.
It is based (and improves) on this previous [PR](https://github.com/NixOS/nixpkgs/pull/257156) which is now outdated. Compared to that, there are several improvements:
* A basic test is added
* `src` has been updated (on GitHub anymore)
* The "font path" issue [discussed there](https://github.com/NixOS/nixpkgs/pull/257156#discussion_r1380341764) has been addressed (see this [comment](https://github.com/NixOS/nixpkgs/pull/257156#issuecomment-2278807153), too)
* A newer version of zutty is used that contains a fix for certain fonts (see details [here](https://gist.github.com/rolfschr/4261ea856535c6007194b2b27f3dee04?permalink_comment_id=5161242#gistcomment-5161242))
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
Backport of merged HyperV fix
NixOS:release-24.05 ← MatthewCash:fix/hyperv-deamons-fcopy-stable
opened 12:32AM - 27 Aug 24 UTC
Backport of #332346 to fix #337475.
For pa… ckage updates please link to a changelog or describe changes, this helps your fellow maintainers discover breaking updates.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
kieeps
September 6, 2024, 8:02am
4528
This hasn’t been laying around for as long as other PRs I’w seen here, but it has a security fix that probably needs to be pushed asap
NixOS:master ← kieeps:master
opened 03:31PM - 05 Sep 24 UTC
New update of Teleport 16.
Mostly security related… fixes in [16.1.8](https://github.com/gravitational/teleport/releases/tag/v16.1.8) and [16.2.0](https://github.com/gravitational/teleport/releases/tag/v16.2.0)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
New package and module for zwave-js-ui which has an open package request
NixOS:master ← cdombroski:init-zwave-js-ui
opened 09:05PM - 22 Aug 24 UTC
Resolves #230686
zwave-js-ui is a full featured … Z-Wave Control Panel and MQTT Gateway
This PR incorporates both a package and a module to create a service for it if desired
Second package and first module, so let me know if something needs to be changed
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
updates etesync-dav, providing needed fixes
NixOS:master ← ghpzin:etesync-dav/fix-runtime-with-radicale-3.2.2
opened 04:30PM - 31 Aug 24 UTC
Diff: https://github.com/etesync/etesync-dav/compare/v0.32.1...b9b23bf6fba60d420… 12008ba06023bccd9109c08
- contains commit pulled previously pulled with fetchpatch:
https://www.github.com/etesync/etesync-dav/commit/040cb7b57205e70515019fb356e508a6414da11e
- contains commit with changes to log.set_level() from radicale 3.2.2 update (additional second arg - backtrace_on_debug):
https://www.github.com/Kozea/Radicale/pull/1519
https://www.github.com/etesync/etesync-dav/pull/318
Since `radicale` update to 3.2.2 (https://github.com/NixOS/nixpkgs/pull/321108) `etesync-dav` fails during runtime with error related to changes to `log.set_level` (additional second arg).
Fixes test run of `nixosTests.etesync-dav` (fails since `2024-06-20` - merge of `radicale` update):
https://hydra.nixos.org/job/nixos/trunk-combined/nixos.tests.etesync-dav.x86_64-linux
https://hydra.nixos.org/build/270729013
Error log:
```text
machine # Traceback (most recent call last):
machine # File "/nix/store/wd2by7xjf0cx15nwdxg395x0zsfja50g-etesync-dav-0.32.1/bin/.etesync-dav-wrapped", line 164, in <module>
machine # radicale_main.run(radicale_args + sys.argv[1:])
machine # File "/nix/store/wd2by7xjf0cx15nwdxg395x0zsfja50g-etesync-dav-0.32.1/lib/python3.12/site-packages/etesync_dav/radicale_main/__init__.py", line 136, in run
machine # log.set_level(configuration.get("logging", "level"))
machine # TypeError: set_level() missing 1 required positional argument: 'backtrace_on_debug'
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This PR was originally reviewed by Sandro in April, but I struggled with the request to unvendor the dependencies because it required patching the build definitions and I was too unfamiliar with CMake scoping and namespacing.
I managed to finally see it through last week and would be happy to get this PR over the finishing line.
NixOS:master ← niklaskorz:shaka-packager-3.0.4
opened 01:51PM - 05 Apr 24 UTC
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
Thanks to shaka-packager now using CMake as build system, we can replace the current use of upstream binaries with a from-source build. The changelogs since v2.6.1 can be found here:
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.0
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.1
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.2
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.3
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.4
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.1.0
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.2.0
As so far shaka-packager did not have an assigned nixpkgs maintainer, I added myself.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
