This PR was originally reviewed by Sandro in April, but I struggled with the request to unvendor the dependencies because it required patching the build definitions and I was too unfamiliar with CMake scoping and namespacing.
I managed to finally see it through last week and would be happy to get this PR over the finishing line.
NixOS:master
← niklaskorz:shaka-packager-3.0.4
opened 01:51PM - 05 Apr 24 UTC
## Description of changes
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
Thanks to shaka-packager now using CMake as build system, we can replace the current use of upstream binaries with a from-source build. The changelogs since v2.6.1 can be found here:
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.0
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.1
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.2
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.3
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.0.4
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.1.0
- https://github.com/shaka-project/shaka-packager/releases/tag/v3.2.0
As so far shaka-packager did not have an assigned nixpkgs maintainer, I added myself.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [x] Tested, as applicable:
- [24.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2405.section.md) (or backporting [23.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2305.section.md) and [23.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2311.section.md) Release notes)
Thanks a lot if you do!
SebTM
September 8, 2024, 11:53am
4540
iynaix
September 8, 2024, 12:58pm
4541
Would be really nice to have this for 24.11:
NixOS:master
← JerrySM64:installer
opened 11:13AM - 08 Jul 24 UTC
Add git and rsync to installation-cd-base so the mini… mal iso also has those tools out of the box. Fixes #325170
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] Tested, as applicable:
- [X] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review rev HEAD"`. Note: all changes have to be committed, also see [nixpkgs-review usage](https://github.com/Mic92/nixpkgs-review#usage)
- [X] Tested basic functionality of all binary files (usually in `./result/bin/`)
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md).
