This program has been trying to be packaged for a long time and the program’s been updated quite a few times and an older PR has went stale quite a few times, so a review would be highly appreciated.
NixOS:master
← Saturn745:sgdboop-init
opened 11:05PM - 12 Sep 24 UTC
## Description of changes
For package updates please link to a changelo… g or describe changes, this helps your fellow maintainers discover breaking updates.
This is a new PR based on @puffnfresh's original PR #269369, which went stale. I wasn't sure if I could do this or not, but I was told by a few people that I could so long as I kept Puffnfresh as a commiter, so I did. I also fixed trailing whitespace causing the editorconfig check to fail, [updated the license for SGDBoop](https://github.com/SteamGridDB/SGDBoop/commit/4f39135617df5b0fbdeb36681ecbd727e4ea9503), and moved all of the packages to a `by-name` structure. One thing I was sure about was whether to keep Puffnfresh as a maintainer of these packages since his original PR went stale and nothing has been said from him. I did remove him from the maintainers of these, but I will add him back if he does want to maintain them.
I apologize for any mistakes. I am still learning some things, and please let me know of any issues.
Closes: #269369, #220937
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
Thanks a lot if you do!
