This small PR is here for about 2 years. I’m waiting for a long time.
https://github.com/NixOS/nixpkgs/pull/63899
https://github.com/NixOS/nixpkgs/pull/126302
Help wanted to make the closure less bloated.
https://github.com/NixOS/nixpkgs/pull/123472
ceph-csi package init
need this for working on Ceph CSIMigration for kubernetes v1.21.
Bumping review for nixos/mattermost: add preferNixConfig option, plugin support, and tests by numinit · Pull Request #119200 · NixOS/nixpkgs · GitHub. Resolves Mattermost service fails to build in pure evaluation mode (e.g. with flakes) · Issue #111076 · NixOS/nixpkgs · GitHub.
https://github.com/NixOS/nixpkgs/pull/123915
Drops enca as dependency for libass, which has already not been supported since version 0.13.0. Does not give any functional changes (and if we had ca-derivations, it would only be a rebuild of this package, since the build result matches exactly).
This will enable cross-compilation for libass as well.
https://github.com/NixOS/nixpkgs/issues/65680#issuecomment-864289312
It’s quite old but I’m using it on my system without problems
https://github.com/NixOS/nixpkgs/pull/126289
It’s basically ready, but it needs some discussion about what to do with modules creating unsafe (permission-wise) wrappers.
https://github.com/NixOS/nixpkgs/pull/129279
Would much appreciate a swift review if possible, I’ve got about a dozen more PRs that I’m gonna open after this, they all depend on this though since it adds me as a maintainer ![]()
https://github.com/NixOS/nixpkgs/pull/129387
https://github.com/NixOS/nixpkgs/pull/129388
https://github.com/NixOS/nixpkgs/pull/129389
https://github.com/NixOS/nixpkgs/pull/129390
https://github.com/NixOS/nixpkgs/pull/129423
https://github.com/NixOS/nixpkgs/pull/129426
Keep old backup when postgresqlBackup fails.
