PRs ready for review _
https://github.com/NixOS/nixpkgs/pull/127367
I think this small PR would be a useful change in default behavior for boot.initrd.secrets to allow secrets with paths within /run/keys to avoid extra copies onto disk-backed filesystems. This also makes them easier to use them for ZFS native encryption key file arguments and recreating the initrd from the secrets already in /run/keys.
PTAL, thank you!
https://github.com/NixOS/nixpkgs/pull/129449
https://github.com/NixOS/nixpkgs/pull/129970
Tests for booting installation media on aarch64.
https://github.com/NixOS/nixpkgs/pull/124415
https://github.com/NixOS/nix/pull/4638
https://github.com/NixOS/nixpkgs/pull/130308
Please help test the Pantheon 6 upgrade (detailed instructions provided) if you are interested in that. :grin:
https://github.com/NixOS/nixpkgs/pull/130380
https://github.com/NixOS/nixpkgs/pull/131760
https://github.com/NixOS/nixpkgs/pull/131754
https://github.com/NixOS/nixpkgs/pull/131267
Hi, my first pr… I’m not sure what there is to do or what it stops from being merged… it just makes a normal grub feature available for nixos
(now with correct pr link)
https://github.com/NixOS/nixpkgs/pull/109302
https://github.com/NixOS/nixpkgs/pull/121693
https://github.com/NixOS/nixpkgs/pull/131078
Still languishing in limbo
https://github.com/NixOS/nixpkgs/pull/73106
Other ready
https://github.com/NixOS/nixpkgs/pull/74085#issuecomment-898758834
https://github.com/NixOS/nixpkgs/pull/84115#issuecomment-898758840
https://github.com/NixOS/nixpkgs/pull/133486
Hi,
this is my first pull request and I would need some help. Especially how to use $out in configureFlags list. These are not evaluated and I set the flag needing $out in preConfigure. Can you confirm, that this is the problem stopping the merging process?
https://github.com/NixOS/nixpkgs/pull/134067
Includes a critical security patch, would be great to merge asap:
Just a simple backport of a new package that I’d like to install locally without patching or so:
