PRs ready for review _
Was messy at start, now we’re good to go!
I could use someone to proof-read nixos/nextcloud: add some notes for `Error: Command "upgrade" is not defined.` by Ma27 · Pull Request #135958 · NixOS/nixpkgs · GitHub :slight_smile:
I’ve got a few that should be ready to go!
@julm I’m out for the weekend with zero technology, but I’ll take a look at these when I have a chance thereafter. (especially the sourcehut, thanks!)
~~https://github.com/NixOS/nixpkgs/pull/136848~~
Package looking for review (module has already been reviewed and approved):
Hi, I’m looking for reviews for
thanks!
Test automation for fetchers!
They used to be tricky to hack on because they don’t re-run after completing once. With this technique, we can have tests as usual.
Can someone take a look at this, that has been ignored for a couple of weeks (maintainer is not responding, and the same happened with #134390, but that one was merged).
It should be merged, because the complicated license doesn’t allow free distribution of that code.
And I need it to be merged so I can send my other PRs to fix the build on darwin and fix/enable the Python interface.
I can take over maintenance, since I’ve put a lot of work to fix the package (including merged #134390 and #134393, and my upcoming PRs).
Can someone review these PRs open for a couple of weeks?
This change of the resilio-sync module has been sitting for a couple of months. It introduces the option of managing resilio sync secrets using secret files, so those secrets don’t need to end up in the nix store. I’d super appreciate a review!
