Working on adding python package typical to nixpkgs. It depends on package future-typing . Have a working derivation for it, but must disable one test file. The test fails because it use an encoder that future-typing install. But it seems that it is not available when tests runs. Any help to get the last test file to work?
It is the header # -*- coding: future_typing -*- in the following file that is making problems: https://github.com/PrettyWood/future-typing/blob/4bb6bb2bdfbc92676f86e9cd75193b5cae8d121e/tests/test_future_typing.py
NixOS:master ← kfollesdal:kfollesdal/typical
How can we get the tests in tests/test_future_typing.py to work?
It fails s… ince it does not find the encoder `future_typing` that is installed by `future-typing`. So it seems that the encoder is not available in the test environment.
The test file tests/test_future_typing.py use the encoder by the header with `# -*- coding: future_typing -*-` but the test fails with error `SyntaxError: unknown encoding: future_typing`. How can we fix this?
The test file that fails is https://github.com/PrettyWood/future-typing/blob/main/tests/test_future_typing.py
liff
October 13, 2021, 8:03pm
602
Here’s a small quality of life improvement for Gradle users. Inconveniently large rebuild for what it is but suppose that cannot be helped.
NixOS:staging ← liff:gradle-native
opened 07:57PM - 30 Aug 21 UTC
Thanks a lot if you do!
###### Motivation for this change
If ncurses is available Gradle can use it to prettify its output and show progress during task execution. The fixup step patches the bundled native libraries with libstdc++ but not with ncurses, which means that Gradle will always use the (non-pretty) fallback native platform libraries.
Patching the native platform libraries with ncurses5 and ncurses6 dependencies fixes the issue.
For some reason both ncurses5 and ncurses6 are required. Gradle will refuse to start if, for example, the ncurses5 native platform jar is missing.
###### Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] For non-Linux: Is `sandbox = true` set in `nix.conf`? (See [Nix manual](https://nixos.org/manual/nix/stable/#sec-conf-file))
- [ ] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [ ] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review wip"`
- [x] Tested execution of all binary files (usually in `./result/bin/`)
- [21.11 Release Notes (or backporting 21.05 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2111-release-notes)
Poscat
October 15, 2021, 11:49am
604
Not my own PR, but It would nonetheless be great if someone can get this merged.
NixOS:master ← griff:dovecot-precompile
opened 11:28AM - 25 Feb 18 UTC
This PR does 4 different things in the 3 com… mit:
* Adds test of sieve scripts to `nixos/tests/dovecot.nix`
* Patches dovecot_pigeonhole with this change dovecot/pigeonhole#4
* Adds builder to precompile sieve scripts
* Adds more options relating to sieve scripts to dovecot2 module
###### test of sieve scripts
Before making changes to how sieve scripts were handled I thought it best that the dovecot test included some testing of the sieve script functionality.
###### Patching dovecot_pigeonhole and builder to precompile scripts
One of the changes I wanted to make was to precompile sieve scripts as part of a Nix derivation. But to do that dovecot_pigeonhole needs to be changed since when source and compiled script have same mtime it thinks that the compiled script is out of date. I have tried to upstream that change with dovecot/pigeonhole#4 but it is as of yet not merged.
The builder does its compilation in the install phase because the compiled `.svbin` files contain a reference to the full path of the source `.sieve` file and so the source needs to be in `$out` when doing the compile.
###### Sieve related options in the dovecot2 module
When precompiling sieve scripts the compiler needs a dovecot configuration that defines `sieve_plugins`, `sieve_extensions` and `sieve_global_extensions` to know which extensions and plugin functionality to allow but you can’t just use the dovecot2 config file directly because that would create a dependency cycle. So to better support precompilation I have added explicit options for these 3 things to the dovecot2 module so that I can reuse their values when precompiling.
The `sieveScripts` option followed very closely how dovecot configures global scripts and was a direct mapping from attribute name to `sieve_${attribute name}` which has some problems. E.g. if you defined `sieveScripts.after2` without defining `sieveScripts.after` your script would never be called. It also wasn’t totally clear without reading the dovecot documentation what scripts you could define.
So I have added explicit options `sieve.beforeScripts`, `sieve.defaultScript`, `sieve.afterScripts` and `sieve.discardScript` for each of the scripts you can define with `beforeScripts` and `afterScripts` being lists of paths that are automatically translated to the correct numbered dovecot configuration and with the added bonus that multiple definitions of the option are merged into one list. I have also included functionality so that existing configurations that use the `sieveScripts` option continue to work as before but now with a warning pointing to the new options.
The other place were you might use global sieve scripts and so would like to precompile the scripts is when using the `imapsieve` plugin. Before there were no options for this so I have added options for enabling and configuring `imapsieve` with support for automatic precompilation of scripts.
##### Things done
- [ ] Tested using sandboxing ([nix.useSandbox](http://nixos.org/nixos/manual/options.html#opt-nix.useSandbox) on NixOS, or option `build-use-sandbox` in [`nix.conf`](http://nixos.org/nix/manual/#sec-conf-file) on non-NixOS)
- [X] NixOS
- [ ] macOS
- [ ] other Linux distributions
- [X] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [ ] Tested compilation of all pkgs that depend on this change using `nix-shell -p nox --run "nox-review wip"`
- [X] Tested execution of all binary files (usually in `./result/bin/`)
- [X] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/.github/CONTRIBUTING.md).
fabianh
October 18, 2021, 4:59pm
607
NixOS:master ← illustris:hadoop
opened 10:05PM - 09 Oct 21 UTC
The current system of building hadoop creates a monolithic fixed-output "build-deps" derivation by running maven in a loop. This makes updating the packages and using custom builds of hadoop much more difficult. It also forces expensive full rebuilds for minor changes. Most of the difficulties in building the package from source are because of maven's unusual way of doing things, such as returning different checksums for the same files, or downloading dynamically linked binaries at build time. The new package can directly accept upstream builds from apache, or binaries from your own custom builds.
The HDFS and YARN modules in their present state require too much manual configuration to spin up a cluster. The changes in this PR adds many sane defaults that make it possible to start a cluster with very little manual configuration. See `nixos/tests/hadoop/hadoop.nix` for an example.
The existing tests for HDFS and YARN are simply checking whether the namenode, datanode, resourcemanager and nodemanager services start up and expose their web UIs. This is not enough to check if the services are able to communicate, store data and run workloads. The newly added test will test the following:
- Does the HDFS cluster exit safemode after startup?
- Does the YARN resourcemanager register the nodemanager?
- Does a simple mapreduce job using YARN for compute and HDFS for storage succeed?
##### Things done
###### Package:
- Update to latest releases as per https://hadoop.apache.org/releases.html
- Point the `hadoop` package to the latest 3.x release
- Add `hadoop2` pointing to the latest hadoop 2.x release
- Replace maven for-loop fixed output builds with binary releases
- Add more easily accessible options to selectively enable native libraries
- set defaults for HADOOP_HOME and HADOOP_CONF_DIR with makeWrapper
###### Module:
- Remove `HADOOP_HOME` from service config as it is now correctly set by the package
- Set default restart policy for all services to `always`
- Add an option to add additional files to `HADOOP_CONF_DIR`
- Add hadoop CLI tools to systemPackages when any hadoop service is enabled
- Add restartIfChanged option
- Add support for LinuxContainerExecutor, make it the default executor type
- Add firewall defaults and options
- Generate container-executor.cfg from options
##### Tests
- Add cluster test for HDFS and YARN
- Add unified test for HDFS+YARN+mapreduce
##### Todo
- Add documentation
##### Future work
In its current state, the module doesn't make it easy to spin up an [HA HDFS cluster with QJM](https://hadoop.apache.org/docs/stable/hadoop-project-dist/hadoop-hdfs/HDFSHighAvailabilityWithQJM.html). Usually this would require a series of manual steps to initialize the cluster. In subsequent PRs I'll try to make a 1-click deployment of a production-ready HA hadoop cluster possible.
While building from source is very inconvenient with nix's currently limited support for maven, it would be nice to provide the option to build hadoop from source eventually.
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tested via one or more NixOS test(s) if existing and applicable for the change (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))
- [x] Tested compilation of all packages that depend on this change using `nix-shell -p nixpkgs-review --run "nixpkgs-review wip"`
A few minor changes are pending, but I’d appreciate a review at this stage.
I have reviewed this but no one replied.
This PR is ready for review, can someone please take a look?
Yarny
October 24, 2021, 2:10pm
615
This one brings all PPD files from https://openprinting.org/printers to nixpkgs. It also adds a new setup hook that helps patching ppd files. Maybe someone with an old printer or with experience in packaging CUPs drivers can give it a try.
https://github.com/NixOS/nixpkgs/pull/133537
Have a bunch of package requests ready for review
NixOS:master ← WolfangAukang:binance
opened 11:58PM - 22 Oct 21 UTC
#142603
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master ← WolfangAukang:protonvpn
opened 04:35AM - 23 Oct 21 UTC
#140367
###### Things done
Ported two necessary libraries and tested the new GUI client, which works as intended.
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
The only issue is that the executable is called `protonvpn`, and this might collide with the `protonvpn-cli` which has the same name.
NixOS:master ← WolfangAukang:pocket-casts
opened 03:29PM - 23 Oct 21 UTC
#133530
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master ← WolfangAukang:morgen
opened 11:13PM - 23 Oct 21 UTC
#131496
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
NixOS:master ← WolfangAukang:gaphor
opened 02:56AM - 24 Oct 21 UTC
#142459
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
r-burns
October 25, 2021, 12:13am
617
Routine patch version bump, lots of rebuilds but well-tested and unlikely to cause breakage:
NixOS:staging ← r-burns:srtp
opened 11:16PM - 08 Oct 21 UTC
Release notes: https://github.com/cisco/libsrtp/releases
Diff: https://github.c… om/cisco/libsrtp/compare/v2.4.0...v2.4.2
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested execution of all binary files (usually in `./result/bin/`)
fabianh
October 25, 2021, 8:38pm
618
NixOS:master ← LibreCybernetics:update-android-studio-canary
opened 02:54AM - 25 Oct 21 UTC
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Android Studio (Canary) version bump
NixOS:master ← rowanG077:cloudcompare-pcd
opened 08:58PM - 13 Oct 21 UTC
Update cloudcompare and add pcl plugin for mo… re file format support
Released version doesn't work with packaged PCL because it's too new. Considering that a release is a year ago it's unreasonable to wait for it.
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
CloudCompare version bump
NixOS:master ← rowanG077:update-intel-compute-runtime
opened 08:31PM - 23 Oct 21 UTC
`intel-compute-runtime` is quite old. In fact… opencl is not working properly on Intel 11th gen integrated GPUs. This PR updates it to the most recent version. This means a few dependencies also had to be updated. Due to this https://github.com/NixOS/nixpkgs/pull/130127 is kind of obsolete. The packaged version of this PR is not as new as that one because that version is not compatible. Are you fine with this @kvtb?
Fixes https://github.com/NixOS/nixpkgs/issues/142566.
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
intel-compute-runtime version bump. Makes opencl work on 11th gen intel cpus
