gepbird
August 8, 2025, 8:29am
5752
This has a long history, TLDR: it’s been waiting for 10 months, it’s ready apart from some smaller missing features, which are not planned in this PR: xppen_{3,4}: init at {3.4.9-240607,4.0.7-250117}; nixos/xppen: init by gepbird · Pull Request #351647 · NixOS/nixpkgs · GitHub
searching for reviewer with write access to merge this little package
master ← nukdokplex:age-plugin-openpgp-card
opened 06:50PM - 18 Jun 25 UTC
added age-plugin-openpgp-card package [wiktor-k/age-plugin-openpgp-card](https:/… /github.com/wiktor-k/age-plugin-openpgp-card)
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
- [ ] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
Anyone got time to review my tiny PR for the sanoid module? Just adds a few missing options and should be a quick review and it has been out quite a while now
master ← f-koehler:add-missing-sanoid-options
opened 05:02AM - 30 May 25 UTC
## Things done
- [x] x86_64-linux
- [ ] aarc… h64-linux
- [ ] x86_64-darwin
- [x] Tested, as applicable:
I have now activated the cli tool from gz-cmake. Therefore, in the long term, I will probably have to check all the gazebo libraries I have built so far to see if they are compatible with the cli tool.
gz-cmake: activated cli capabilities
master ← donottellmetonottellyou:donottellmetonottellyou/legendsviewer-next
opened 03:14PM - 10 May 25 UTC
## Add legendsviewer-next
### Commits
- maintainers: add donottellmetnotte… llyou
- legendsviewer-next: init at 1.2.0
- legendsviewer-next: add test
- legendsviewer-next: refactor
- legendsviewer-next: move tests to installCheckPhase
- legendsviewer-next: move backend into package.nix
### Description
[LegendsViewer-Next](https://github.com/Kromtec/LegendsViewer-Next) is a cross-platform revamp (by the same author) of the [original Windows-only LegendsViewer](https://github.com/Kromtec/LegendsViewer), a legends-mode explorer for the indie game Dwarf Fortress. LegendsViewer-Next supports world information overviews, maps, populations, war/battle death tolls, and has a very user-friendly interface.
LegendsViewer-Next hosts a web app on port 8081 with the api on port 5054. Its configuration on Linux is stored at `~/.config/LegendsViewer`, currently only `bookmarks.json`.
### Tests
Currently, there is one unit test, which makes sure the frontend serves an html document and the backend reports the correct version, and both are working.
### Questions
Is it acceptable to use `import` on an internal module, like I did here? If not, how would I fix this?
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- ~~[ ] `sandbox = relaxed`~~
- [x] `sandbox = true`
- ~~[NixOS test(s)](https://nixos.org/manual/nixos/unstable/index.html#sec-nixos-tests) (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))~~
- ~~or, for functions and "core" functionality, tests in [lib/tests](https://github.com/NixOS/nixpkgs/blob/master/lib/tests) or [pkgs/test](https://github.com/NixOS/nixpkgs/blob/master/pkgs/test)~~
- ~~made sure NixOS tests are [linked](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md#linking-nixos-module-tests-to-a-package) to the relevant packages~~
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
- ~~[ ] (Package updates) Added a release notes entry if the change is major or breaking~~
- ~~[ ] (Module updates) Added a release notes entry if the change is significant~~
- ~~[ ] (Module addition) Added a release notes entry if adding a new NixOS module~~
This pr still only has one review after months!
It is a popular tool for Dwarf Fortress players that has been getting exposure by some YouTubers as well (such as Blind , VonGalactic , etc) and right now nobody on Linux has packaged it yet.
The open source tool allows for in-depth exploration of Dwarf Fortress legends mode with a lot of views and details that would otherwise be hard or impossible to view in-game. It also supports dfhack legends_plus exports!
ejiek
August 12, 2025, 10:34am
5762
New bitmap font. PR is going to be 5 month tommorow =]
master ← ejiektpobehuk:kirsch-font
opened 04:42PM - 14 Mar 25 UTC
Adds [kirsch](https://github.com/molarmanful/kirsch) font - A versatile bitmap f… ont with an organic flair.
closes https://github.com/molarmanful/kirsch/issues/9
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
bzadm
August 12, 2025, 4:26pm
5765
master ← weriomat:checkmk-agent
opened 01:18PM - 17 Apr 25 UTC
The checkmk agent is service to monitor *nix style systems : https://checkmk.com… /product/latest-version
Closes [#325379](https://github.com/NixOS/nixpkgs/issues/325379)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) and [25.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) Release notes)
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
Updated for 25.11 rl
It has been reviewed once already but needs another review (after merge conflicts were resolved)
master ← martinetd:rmfakecloud
opened 08:08AM - 28 Jun 25 UTC
fix compat with rm 3.20
See https://github.com/ddvk/rmfakecloud/pull/364
(… note it also apparently requires adding eu.tectonic.remarkable.com to the dozen of other redirected domains in /etc/hosts... not sure that's worth writing in release notes as upstream didn't point it out in their own release notes?)
https://github.com/ddvk/rmfakecloud/releases/tag/v0.0.25
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
rmfakecloud 0.0.24 doesn’t work well with the latest remarkable OS so this is actually quite annoying to be in limbo, any review/merge would be appreciated.
EDIT: done, thanks!
gaelj
August 14, 2025, 10:53am
5767
After running into a build failure due to a system activation script that has grown too large, I propose to generate each script individually in its own file and source these files in the main activation script.
Review and any improvement suggestions would be much appreciated.
master ← gaelj:make-activation-scripts-scalable
opened 10:16PM - 13 Aug 25 UTC
I narrowed down a build failure with an 'argument too long' error, to the size o… f my activation script, which is passed as an argument to a shell during activation. It had grown quite huge, due to having ~75 agenix secrets in my config, which generates quite a lot of activation script for each key.
I figured the best way to solve this issue was in NixOS: instead of concatenating the contents of each activationScript entry in a single file, we could generate individual script files to the nix store for each activationScript entry, and source each of them in the main activation script. This has the added benefit that the activation script now shows more clearly the order of execution of each script, instead of having to dig in a blob of concatenated scripts.
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested, as applicable:
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
iedame
August 14, 2025, 2:53pm
5768
master ← iedame:update-megasync
opened 12:28PM - 02 Aug 25 UTC
Updated `megasync` to version 5.14.0.2 and new hash, added myself to maintainers… and added my name to `maintainers/maintainer-list.nix`. This update was made based on information from `github.com/meganz/MEGAsync/releases/`.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
It has been reviewed once and approved, any help is appreciated.
Thank you!
alurm
August 16, 2025, 5:24am
5771
Hey. This is my first message on Discourse. Please check out my PR:
master ← alurm:patch-1
opened 01:05PM - 23 Jul 25 UTC
```diff
- [allowSubstitutes]: https://nixos.org/nix/manual/#adv-attr-allowSubst… itutes
- [preferLocalBuild]: https://nixos.org/nix/manual/#adv-attr-preferLocalBuild
+ [allowSubstitutes]: https://nix.dev/manual/nix/latest/language/advanced-attributes.html#adv-attr-allowSubstitutes
+ [preferLocalBuild]: https://nix.dev/manual/nix/2.30/language/advanced-attributes.html#adv-attr-preferLocalBuild
## Things done
I have tested this with `nix build github:alurm/nixpkgs/patch-1#htmlDocs.nixpkgsManual.x86_64-linux`, seems to fix the issue.
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
It’s a two line like change to fix broken link in docs I have noticed.
