heitorpb
September 12, 2025, 12:45pm
5856
My PR was reviewed, but the CI is stuck for more than a month now. I canβt add myself as a reviewer. I force pushed it a couple of times to retrigger, but the same check is in the queued state.
master β heitorPB:pkgs/tcping-rs
opened 08:46PM - 16 Jul 25 UTC
Add [`tcping`](https://github.com/lvillis/tcping-rs) program.
I named it `tcp⦠ing-rs` like upstream.
## Things done
- Built on platform(s)
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
- [ ] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
nadir
September 14, 2025, 9:20am
5858
master β lagerstrom:update_feishin
opened 11:08AM - 25 Jul 25 UTC
Feishin have switched to start using pnpm instead of npm. Updated the nix packag⦠e accordingly. This will bring us from version `0.12.6` to version `0.18.0` which is the latest release of Feishin.
https://github.com/jeffvli/feishin/releases
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
Ready since end of July I think.
RatCornu
September 15, 2025, 6:49pm
5864
tylerjl
September 15, 2025, 11:06pm
5865
Hey yβall. Opened this PR a month or so ago; just recently updated it again to the latest nirius release, would be nice to get it in:
master β tylerjl:tylerjl/init-nirius
opened 04:43AM - 20 Aug 25 UTC
[nirius](https://git.sr.ht/~tsdh/nirius) is a sibling daemon to niri that facili⦠tates a few extra capabilities. It's primary use is as a userland daemon, so the intent here is to eventually get a module into home-manager, but we can define the package in `nixpkgs` upstream.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
balsoft
September 16, 2025, 3:47pm
5866
A bunch of very simple, small PRs:
Version bump, maintainer non-responsive:
master β tweag:ubelt-137
opened 03:30PM - 18 Jun 25 UTC
Tests that were broken are fixed in the new release, see https://github.com/Erot⦠emic/ubelt/issues/161.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [x] `sandbox = true`
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
Fix of an upstream URL for an important python package, which is for some reason unmaintained:
staging β tweag:jherland/fix-docutils
opened 01:33PM - 14 Jul 25 UTC
Commits:
- `python3Packages.docutils`: Fix upstream URL (repo.or.cz -> sourcefor⦠ge)
- `python3Packages.docutils`: Various minor updates/modernization
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
balsoft
September 16, 2025, 3:49pm
5867
Adding a few new ML-adjacent python libraries; we (Tweag) are happy to assume maintainership.
master β tweag:jherland/add-pytorch-tabnet
opened 03:12PM - 20 Jun 25 UTC
## Things done
- [x] x86_64-linux
- [ ] aarc⦠h64-linux
- [ ] x86_64-darwin
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
master β tweag:jherland/add-python-cometx
opened 01:07PM - 25 Jun 25 UTC
These packages depend on each other (cometx -> comet-ml -> everett), so I bundle⦠them in one PR. Happy to split into separate PRs if that is preferable (but I'm not sure how to properly encode PR dependencies between PRs started from a fork).
Commits:
- **python3Packages.everett: init at 3.4.0**
- **python3Packages.comet-ml: init at 3.49.11**
- **python3Packages.cometx: init at 2.3.1**
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
master β tweag:jherland/add-python-linearmodels
opened 11:36AM - 02 Jul 25 UTC
linearmodels depends on pyhdfe, thus I've put both in this PR. Happy to split in⦠to 2 PRs, although I'm not sure how to set up PR dependencies properly.
Commits:
- `python3Packages.pyhdfe`: init at 0.2.0
- `python3Packages.linearmodels`: init at 6.1
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
balsoft
September 16, 2025, 4:00pm
5868
Reducing the transitive closure size of nix-prefetch-git (and thus fetchgit, cabal2nix, etc) by ~150 MB, bringing joy to everyone with a small storage space:
master β tweag:jherland/fix-nix-prefetch-git
opened 02:37PM - 14 Jul 25 UTC
This reduces the transitive closure size of nix-prefetch-git from ~355MB
to ~163β¦ MB.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This prevents breaking rebuilds
master β eclairevoyant:cue-valid
opened 01:59AM - 08 Aug 25 UTC
- **cue.passthru: ensure all attrs use final overriden package**
- **cue: add t⦠ests.cue-validation to tests**
See #430141 and #431813 for context.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
