I would appreciate if someone could re-review this PR, as it’s been sitting for a while.
noanswer
September 19, 2025, 10:52am
5876
Same here: added GCC as an objective c compiler, added gnustep-packages that use gcc by b521f771d8991e6f1d8e65ae05a8d783 · Pull Request #435551 · NixOS/nixpkgs · GitHub
It is just a small addition that enables us to use the Objective-C-capabilities of GCC, which is currently disabled, this builds a second set of compilers and tools that have objc enabled (and leaves the current gcc untouched)
azey7f
September 20, 2025, 10:14pm
5880
master ← azey7f:vpp-service
opened 08:25PM - 10 Oct 24 UTC
## Description of changes
Module & associated tests for #346281.
Includes … an RFC42 `settings` option using a custom parser based on [znc](https://github.com/NixOS/nixpkgs/blob/c636130b369ff944bb1c3560c8bb9377e6082975/nixos/modules/services/networking/znc/default.nix)'s and support for multiple instances similar to authelia's module. The test is pretty basic and verifies routing functionality between 2 hosts with VPP acting as the router.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [x] Tested, as applicable:
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
Adds a (relatively complex) module + simple tests for an existing package, PR’s been sitting open for so long I changed genders since I made it
kemichal
September 22, 2025, 10:42am
5884
My PR has been sitting for a few months now.
master ← Kemichal:prometheus-http-config-options
opened 09:24AM - 13 Apr 25 UTC
My first nix contribution.
Added missing configuration options.
https://prom… etheus.io/docs/prometheus/latest/configuration/configuration/#http_config
I have tested the option on my server, not sure if this means I should check the "Tested" box below.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
