master β alexshpilkin:fio-nbd
opened 02:11AM - 12 Jul 25 UTC
FIO has a mode where it can run against a local or remote [NBD][] server instead⦠of an actual file or block device, using [libnbd][] to actually speak the protocol. This can help when testing unconventional I/O gadgets by running them as userspace NBD servers instead of plugging them into the kernel, Qemu, or the like, when playing block-device mix-and-match games with [nbdkit], etc.
[NBD]: https://github.com/NetworkBlockDevice/nbd
[libnbd]: https://libguestfs.org/libnbd.3.html
[nbdkit]: https://libguestfs.org/nbdkit.1.html
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
- [x] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
It doesnβt seem like fio has any designated maintainers (or has had them, ever?), even though a number of high-profile people (already tagged for review) have taken care of it over the years. So Iβm not really sure what I should do here.
I would appreciate a re-review on this:
master β algorithmiker:tango
opened 05:00PM - 22 Aug 25 UTC
- Tango is an open source distributed [SCADA](https://en.wikipedia.org/wiki/SCAD⦠A) control system.
Homepage: https://www.tango-controls.org/
- Jive is a GUI browser for a running Tango server.
I've tried to package it from source, but ran into issues with Maven dependency resolution such as
https://gitlab.com/tango-controls/jive/-/issues/79 and https://gitlab.com/tango-controls/jive/-/issues/75.
I am not sure if it is possible to compile from source right now *at all*, with the conflicting dependencies.
Supersedes #183077 and #247936
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
Hi, this PR updates the package that controls specific hardwares (Stream Deck). Itβs been ready to merge but got stuck due to the lack of a reviewer with commit access. Additional reviews is also appreciated.
master β sifmelcara:streamcontroller-1-5-0-beta-11
opened 01:04AM - 14 Jun 25 UTC
Fixes #416461
@ciferkey
## Things done
Add 2 new python packages, whi⦠ch are new dependencies required by the new version of streamcontroller. `streamcontroller_streamdeck` is a fork of existing `streamdeck` package made by author of streamcontroller, required by the new version of streamcontroller.
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [Nixpkgs 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/doc/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/doc/manual/release-notes/rl-2505.section.md) Nixpkgs Release notes)
- [NixOS 25.11 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2511.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) NixOS Release notes)
- [ ] Fits [CONTRIBUTING.md](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md), [pkgs/README.md](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md), [maintainers/README.md](https://github.com/NixOS/nixpkgs/blob/master/maintainers/README.md) and other contributing documentation in corresponding paths.
A new package + build fixes for an already packaged fork.
master β midchildan:feat/add-onscripter
opened 12:43AM - 13 Oct 25 UTC
- Add package for ONScripter
- Base the existing package for the fork, ONScripte⦠r EN, on the new package
- Fix Darwin build for ONScripter EN
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] aarch64-darwin
- [X] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [X] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
rnhmjoj
October 16, 2025, 6:59am
5950
master β rnhmjoj:pr-wpa-rootless
opened 06:08PM - 22 Jul 25 UTC
One more step towards zero services running as root.
Inspired by https://github⦠.com/NixOS/nixpkgs/pull/305722
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- Tested
- [x] `nixosTests.wpa_supplicant`
- [x] `nixosTests.networking.networkmanager`
- [x] `nixosTests.connman`
- [x] wpa_supplicant, wpa_cli on my machine
- [x] connman on actual hardware
- [x] networkmanager on actual hardware
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [x] Module update: when the change is significant.
Iβm asking one more time for reviews here. Especially useful would be from someone using NetworkManager or ConnMan.
jtbx
October 16, 2025, 9:07am
5951
master β jtbx-patches:oink-Restart
opened 06:57AM - 19 May 25 UTC
Restart oink automatically when it exits with an error, such as this:
sy⦠stemd[1]: Started Dynamic DNS client for Porkbun.
oink-start[890]: 2025/05/12 23:44:17 error decoding API response: invalid character '<' looking for beginning of value (status: 503)
systemd[1]: oink.service: Main process exited, code=exited, status=1/FAILURE
systemd[1]: oink.service: Failed with result 'exit-code'.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Just a simple fix here, would greatly appreciate if someone could leave a review
master β DoctorDalek1963:sunsetr-bump
opened 11:29AM - 29 Sep 25 UTC
Bump `sunsetr` to `0.10.0`. See the [changelog](https://github.com/psi4j/sunsetr⦠/releases/tag/v0.10.0).
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
Already reviewed, just needs to be merged.
fixed march=native builds because of a gcc bug
master β Redhawk18:opencolorio
opened 06:29PM - 16 Oct 25 UTC
Clang does not reproduce the error. (happens in gcc x64 v3 and v4 march builds) β¦ If anyone can come up with the expression for marking the package as broken on gcc march builds I'd be grateful.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] [Package tests] at `passthru.tests`.
datosh
October 16, 2025, 6:48pm
5954
master β datosh:add-opkssh-service
opened 09:14PM - 18 Jul 25 UTC
[opkssh](https://github.com/openpubkey/opkssh) is a tool which enables ssh to be⦠used with OpenID Connect allowing SSH access to be managed via identities like alice@example.com instead of long-lived SSH keys.
A [package for opkssh](https://github.com/NixOS/nixpkgs/blob/master/pkgs/by-name/op/opkssh/package.nix) is already available in nixpkgs. This provides the binary which needs to be used on the client to generate a keypair, and on the server to verify the key.
The package can be used as is for client, but this service adds the required configuration files which servers need to make authorization decision decisions.
I have tested this, by creating a NixOS VM and connecting to it using `opkssh login` and then simply `ssh test@VM_IP`
```nix
inputs.nixpkgs.url = "path:/home/datosh/code/nixpkgs";
outputs = { self, nixpkgs }: {
nixosConfigurations = {
opkssh-test = nixpkgs.lib.nixosSystem {
system = "x86_64-linux";
modules = [
({ pkgs, ... }: {
services.openssh = {
settings = {
PermitRootLogin = "no";
PasswordAuthentication = true;
services.opkssh = {
providers = {
google = {
issuer = "https://accounts.google.com";
clientId = "206584157355-7cbe4s640tvm7naoludob4ut1emii7sf.apps.googleusercontent.com";
lifetime = "24h";
authorizations = [
user = "test";
principal = "datosh18@gmail.com";
users.users.test = {
isNormalUser = true;
extraGroups = [ "wheel" ];
initialPassword = "test";
system.stateVersion = "25.11";
Link to issue in opkssh repository: https://github.com/openpubkey/opkssh/issues/220
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and others READMEs.
Already reviewed by 06kellyjac . Happy to answer any questions about the project I am adding here or any feedback to get this merged.
