azey7f
November 13, 2025, 5:49pm
6063
master β azey7f:pullimage-oci
opened 01:17AM - 27 Oct 25 UTC
Resolves #451984.
Adds the ability to fetch images as `oci-archive` tarballs,β¦ which makes it possible to preserve the digest specified in `imageDigest` (e.g. for importing into containerd, see the linked issue). The option is disabled by default, so it shouldn't cause any breakage.
I've also updated the docs & `nix-prefetch-docker`, let me know if there's anything else I missed.
cc @NixOS/nix-team @offlinehacker (hopefully I pinged the right people, if not - sorry and please feel free to ignore this)
## Things done
- Built on platform:
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
Approved by one codeowner, but no activity since then.
Hey guys my commit is approved by one person and ready to merge. Itβs my first PR though so I hope I didnβt miss anything.
master β WitteShadovv:init-portmaster
opened 01:26PM - 14 Sep 25 UTC
Add Portmaster application firewall package and NixOS service module.
Portmas⦠ter is a free and open-source application firewall that puts you back in charge of your computer's network activity. This PR adds both the package definition and a NixOS service module for easy system integration.
Package is built from the official Debian package and includes the core firewall engine, web UI, and all necessary assets. The service module provides proper systemd integration with all required capabilities and security hardening.
https://safing.io/portmaster/
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] NixOS tests in nixos/tests.
- [ ] Package tests at `passthru.tests`.
- [ ] Tests in lib/tests or pkgs/test for functions and "core" functionality.
- [ ] Ran `nixpkgs-review` on this PR. See nixpkgs-review usage.
- [x] Module addition: when adding a new NixOS module.
- [x] Fits CONTRIBUTING.md, pkgs/README.md, maintainers/README.md and other READMEs.
Portmaster is a free and open-source application firewall.
I canβt test this one due to the massive amount of rebuilds, I only tested the functionality of the C code.
However it should improve things on Qt environments.
It fixes the environment variable block getting bloated due to duplicated paths. This is important because some apps have majors issues if itβs too big (the EA App for instance fails to launch games if itβs larger than 32768 characters).
And maybe it improves the speed of launching applications a little.
staging β SuperSamus:make-binary-wrapper-deduplicate
opened 03:27PM - 11 Oct 25 UTC
This is mostly meant for `wrapQtApps`, which is why it's implemented only for `m⦠akeBinaryWrapper`.
Qt apps are often launched on top of each other, creating a problem: many of the paths in `XDG_DATA_PATHS`, `QT_PLUGIN_PATH` and `NIXPKGS_QT6_QML_IMPORT_PATH` become duplicated, and these envars are already massive by themselves without this problem.
Starting KDE Plasma, and most paths are seen twice. Open Konsole, and it becomes three times. If it was opened with CTRL+ALT+T, four times.
Why is this a problem?
- The more these paths are duplicated, the slower it becomes to copy the envars, and for the programs to parse them.
- Some programs are buggy and malfunction if the environment variable block is too big. For instance, the EA App (via Wine) is unable to launch games if there are more than 32768 characters in the block, a number easily surpassable due to this problem.[^1]
- It's ugly typing `env` and seeing this massive wall of duplicated paths.
Because there is no reason for the same path to appear multiple times, this change removes a path if it's already in the list, adding it back to the start or the end.
### Notes
I am unable to locally test this change due to the massive amount of rebuilds.
I did test the functionality of the C code outside nixpkgs.
In terms of performance, I tested adding new paths with both the old and new algorithm, and there is no measurable difference: it's basically dependent only on the length of the string, meaning that performance should be improved thanks to the deduplication.
If the path does exist, the algorithm is fast: I tested calling `set_env_prefix` and `set_env_suffix` back and forth with the same value (80 characters long) 1000 times, on an environment variable that is 3000 characters long: it takes only about 1.5 ms.
(Also, should this change apply only to the prefix and not the suffix?)
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
[^1]: Yes I already tried to contact them, yes they ignored me.
A simple bump and versionCheckHook update.
master β adamperkowski:jellyfin-rpc
opened 02:31PM - 12 Nov 25 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch64-linu⦠x
- [ ] x86_64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
Apologies for already posting this, but I just wanted to bump my PR
master β kiranshila:kshila/calceph
opened 05:00AM - 31 Aug 25 UTC
Adds the [CALCEPH](https://www.imcce.fr/inpop/calceph/) C library for working wi⦠th binary ephemeris files.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This should be good to go and about 3 months old. It should be ready to merge.
Annin
November 16, 2025, 8:33am
6071
Packaged a Hyprland plugin
Would really appreciate a review!
master β Anninzy:init-hypr-darkwindow
opened 07:57PM - 20 Oct 25 UTC
Hyprland Plugin to invert Colors of specific Windows!
https://github.com/micha4β¦ w/Hypr-DarkWindow/
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
Unsure if this one can be merged due to unknown / unclear licensing, would appreciate it a lot if someone could take a look and give feedback
master β alexland7219:add-libpkcs11-dnie
opened 09:45PM - 08 May 25 UTC
Add libpkcs11-dnie, the PKCS#11 module for identification using Spanish [DNIe](h⦠ttps://www.dnielectronico.es/PortalDNIe/PRF1_Cons02.action?pag=REF_1112) (National Identity document).
After installation of the package, the user is shown a couple options to finish with the installation:
- Manually add the libpkcs11-dnie.so module to Firefox (location of library is shown).
- If the user is on NixOS, declaratively add the module (the necessary changes to be made are shown).
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [x] Tested basic functionality of all binary files (usually in `./result/bin/`) (Does not apply)
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Several my PRs that are waiting for review:
master β kurnevsky:i2pd-destination-fix
opened 03:35PM - 24 Sep 25 UTC
- dehardcode tunnel types
Different types might have different behaviors, e.g⦠irc tunnel replaces IP address to user's .b32 I2P address.
- remove destination from incoming tunnels
It's currently mandatory for incoming tunnels because it's defined as non-optional string. But it should be needed only for outgoing tunnels.
- add missing common parameters to incoming tunnels
- correct floodfill description
https://i2pd.readthedocs.io/en/latest/user-guide/tunnels/
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
master β kurnevsky:prosody-http-external-url
opened 12:53PM - 06 Sep 25 UTC
This allows to configure http upload via reverse proxy.
https://prosody.im/do⦠c/modules/mod_http_file_share
https://prosody.im/doc/http
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
plasma: add mobile by kurnevsky Β· Pull Request #459790 Β· NixOS/nixpkgs Β· GitHub - this one will probably need someone from KDE maintainers.
Cobalt
November 18, 2025, 6:30am
6077
Approved/Created by package maintainer:
master β Chaostheorie:cr-netbox-fp
opened 12:30PM - 07 Sep 25 UTC
See
https://github.com/netbox-community/netbox-floorplan-plugin/releases/tag/0.β¦ 8.0 for the full changelog. The nix package only needed a version bump but couldn't be tested yet due to a lack of NetBox 4.4 in nixpkgs.
This PR should not be merged until NetBox 4.4 is available, e.g., through #440403.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
