emaiax
December 3, 2025, 11:12pm
6131
Pretty straightforward, just adding a new Prometheus exporter. Many thanks!
master โ emaiax:prometheus-fastcom-exporter
opened 02:09AM - 03 Dec 25 UTC
This PR introduces the `prometheus-fastcom-exporter` package and nixos module foโฆ r configuring the Prometheus fastcom-exporter. This enables monitoring of network speed metrics via Prometheus using Fast.com.
ref: https://github.com/caarlos0/fastcom-exporter
## Things done
- Built on platform:
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
- [x] aarch64-darwin
- Tested, as applicable:
- [x] [Package tests] at `passthru.tests`.
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- Nixpkgs Release Notes
- NixOS Release Notes
I have revised the handling of the existing gazebo packages.
master โ Guelakais:gz-cmake
opened 08:50AM - 04 Dec 25 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch6โฆ 4-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [x] [NixOS tests] in [nixos/tests].
emaiax
December 5, 2025, 3:38am
6134
This PR reintroduces prometheus-speedtest-exporter.
master โ emaiax:prometheus-speedtest-exporter
opened 03:03AM - 05 Dec 25 UTC
This PR reintroduces the `prometheus-speedtest-exporter` package and nixos modulโฆ e for configuring the prometheus speedtest-exporter. This enables monitoring of network speed metrics via Prometheus using the Ookla Speedtest CLI.
speedtest-exporter timeline:
- https://github.com/NixOS/nixpkgs/pull/203012, PR adding the previous speedtest-exporter
- https://github.com/NixOS/nixpkgs/issues/233062, discussions around changing the speedtest-exporter to [caarlos0/speedtest-exporter](https://github.com/caarlos0/speedtest-exporter), but closed as `not planned`
- https://github.com/NixOS/nixpkgs/pull/246320, package removal due to lack of maintainers
The [caarlos0/speedtest-exporter](https://github.com/caarlos0/speedtest-exporter) has been working for years without issues, so I think it's a solid option to bring this exporter back. This exporter requires [pkgs/by-name/oo/ookla-speedtest](https://github.com/NixOS/nixpkgs/blob/7905606cfa51a1815787377b9cb04291e87ebcb4/pkgs/by-name/oo/ookla-speedtest/package.nix) to be available in runtime; however, speedtest-cli is proprietary software.
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [x] x86_64-darwin
Would be awesome to get some other opinions on https://github.com/NixOS/nixpkgs/pull/458928 especially about the overrides and cleaning up old orphans.
Hi, this is a bump for legendsviewer-next, which still hasnโt been merged!
master โ donottellmetonottellyou:donottellmetonottellyou/legendsviewer-next
opened 03:14PM - 10 May 25 UTC
## Add legendsviewer-next
### Commits
- maintainers: add donottellmetnotteโฆ llyou
- legendsviewer-next: init at 1.2.0
### Description
[LegendsViewer-Next](https://github.com/Kromtec/LegendsViewer-Next) is a cross-platform revamp (by the same author) of the [original Windows-only LegendsViewer](https://github.com/Kromtec/LegendsViewer), a legends-mode explorer for the indie game Dwarf Fortress. LegendsViewer-Next supports world information overviews, maps, populations, war/battle death tolls, and has a very user-friendly interface.
LegendsViewer-Next hosts a web app on port 8081 with the api on port 5054. Its configuration on Linux is stored at `~/.config/LegendsViewer`, currently only `bookmarks.json`.
### Tests
Currently, there is one unit test, which makes sure the frontend serves an html document and the backend reports the correct version, and both are working.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- ~~[ ] `sandbox = relaxed`~~
- [x] `sandbox = true`
- [x] Tested, as applicable:
- ~~[NixOS test(s)](https://nixos.org/manual/nixos/unstable/index.html#sec-nixos-tests) (look inside [nixos/tests](https://github.com/NixOS/nixpkgs/blob/master/nixos/tests))~~
- ~~or, for functions and "core" functionality, tests in [lib/tests](https://github.com/NixOS/nixpkgs/blob/master/lib/tests) or [pkgs/test](https://github.com/NixOS/nixpkgs/blob/master/pkgs/test)~~
- ~~made sure NixOS tests are [linked](https://github.com/NixOS/nixpkgs/blob/master/pkgs/README.md#linking-nixos-module-tests-to-a-package) to the relevant packages~~
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
- ~~[ ] (Package updates) Added a release notes entry if the change is major or breaking~~
- ~~[ ] (Module updates) Added a release notes entry if the change is significant~~
- ~~[ ] (Module addition) Added a release notes entry if adding a new NixOS module~~
Hey
This is a manual repackage of the Forge GNOME extension to make it compatible with GNOME 49 until it gets a proper release in EGO. Built from forge-ext/forge@701e758 , which contains some bug fixes needed in GNOME 49.
master โ agustinmista:gnomeExtensions/manually-package-forge
opened 02:22PM - 06 Dec 25 UTC
This extension has not gotten a new release in while, and the latest one in the โฆ GNOME extension repository is not compatible with GNOME 49.
This PR replaces that one with a new one manually packaged directly from GitHub, and which includes fixes to make it work with GNOME 49 again.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
release-25.11 โ backport-465000-to-release-25.11
opened 08:16AM - 04 Dec 25 UTC
Bot-based backport to `release-25.11`, triggered by a label in #465000.
**Beforโฆ e merging, ensure that this backport is [acceptable for the release](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#changes-acceptable-for-releases).**
Even as a non-committer, if you find that it is not acceptable, leave a comment.
Backports the package to 25.11 release, to bump its version and, more importantly, fix the long unresolved issue with missing UI elements.
