Would appreciate a review on this somewhat difficult to package software:
master ← sephalon:qb64pe
opened 04:23PM - 22 Nov 25 UTC
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch6… 4-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
This one’s tricky because it’s in a low-level build hook, but I think the actual bug / fix is pretty straightforward actually
staging ← bmillwood:bmillwood/fix-patch-shebangs-chmod-w
opened 06:35PM - 16 Nov 25 UTC
- Fixes #462298
- Replaces `chmod -w` with `chmod u-w` (and likewise `+w`) in `… patch-shebangs.sh`, so that the only permission we touch is the one that we tested (and the one that we need). Restoring the mode just wasn't working correctly before, because `-w` isn't an inverse of `+w` (except in special cases). As documented in the issue, this is necessary to fix working on scripts with mode 575 (though who uses those?)
- Added a test case that catches this.
- Fixes `restoreReadOnly` stale value by resetting it to an empty string on every loop iteration. This was a much more serious problem, leading the hook to break on scripts with mode 777 as long as you'd already seen a readonly script earlier this invocation.
- Testing this requires a single invocation of `patchShebangs` that visits a readonly file before a read-write one. In general the order of `patchShebangs` is the order of the embedded `find` operation, which is nondeterministic, but I think `find` processes its command line arguments in order, so you could do something like `patchShebangs test-555 test-777` and I think that would do it. This would feel very specific to this one bug, though, and unlikely to be useful in future.
Testing this comprehensively is made more tricky by the fact that modifying this script forces a rebuild of everything. I worked around this by copying the fixed script to another location and replacing the line in the test that sources the real script with one that sources my fixed script (and cherry-picking all my test changes). The test passes in this setup (and fails on the original script).
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Tests in [lib/tests] or [pkgs/test] for functions and "core" functionality.
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
sloi
December 1, 2025, 11:27am
6111
That’s my first contribution to nixpkgs, I would appreciate a review. It already has one approval.
master ← sloschert:add-python-grimp
opened 06:13PM - 26 Oct 25 UTC
Added grimp: https://github.com/python-grimp/grimp
Added import-linter (depends… on grimp) https://github.com/seddonym/import-linter
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [X] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
7karni
December 1, 2025, 5:28pm
6116
Good evening
Please review the linked PR that would close this build issue
Fixes:
Hash mismatch because upstream redirected download URL, probably because the latest version:
Fixed a critical security issue with communication with the iStat Menus daemon.
Thank you for your time!
master ← 7karni:update-istat-menus
opened 11:33AM - 26 Nov 25 UTC
Closes https://github.com/NixOS/nixpkgs/issues/464468
Changelog: https://bjan… go.com/mac/istatmenus/versionhistory/
% file ./result/Applications/iStat\ Menus.app/Contents/MacOS/iStat\ Menus
./result/Applications/iStat Menus.app/Contents/MacOS/iStat Menus: Mach-O universal binary with 2 architectures: [x86_64:Mach-O 64-bit executable x86_64] [arm64]
./result/Applications/iStat Menus.app/Contents/MacOS/iStat Menus (for architecture x86_64): Mach-O 64-bit executable x86_64
./result/Applications/iStat Menus.app/Contents/MacOS/iStat Menus (for architecture arm64): Mach-O 64-bit executable arm64
<img width="512" height="637" alt="Screenshot 2025-11-26 at 17 12 18" src="https://github.com/user-attachments/assets/27992001-fc16-4418-9cb2-2eaa3f6a0dee" />
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
I can’t test this one due to the massive amount of rebuilds, I only tested the functionality of the C code.
However it should improve things on Qt environments.
It fixes the environment variable block getting bloated due to duplicated paths. This is important because some apps have majors issues if it’s too big (the EA App for instance fails to launch games if it’s larger than 32768 characters).
And maybe it improves the speed of launching applications a little.
staging ← SuperSamus:make-binary-wrapper-deduplicate
opened 03:27PM - 11 Oct 25 UTC
This is mostly meant for `wrapQtApps`, which is why it's implemented only for `m… akeBinaryWrapper`.
Qt apps are often launched on top of each other, creating a problem: many of the paths in `XDG_DATA_PATHS`, `QT_PLUGIN_PATH` and `NIXPKGS_QT6_QML_IMPORT_PATH` become duplicated, and these envars are already massive by themselves without this problem.
Starting KDE Plasma, and most paths are seen twice. Open Konsole, and it becomes three times. If it was opened with CTRL+ALT+T, four times.
Why is this a problem?
- The more these paths are duplicated, the slower it becomes to copy the envars, and for the programs to parse them.
- Some programs are buggy and malfunction if the environment variable block is too big. For instance, the EA App (via Wine) is unable to launch games if there are more than 32768 characters in the block, a number easily surpassable due to this problem.[^1]
- It's ugly typing `env` and seeing this massive wall of duplicated paths.
Because there is no reason for the same path to appear multiple times, this change removes a path if it's already in the list, adding it back to the start or the end.
### Notes
I am unable to locally test this change due to the massive amount of rebuilds.
I did test the functionality of the C code outside nixpkgs.
In terms of performance, I tested adding new paths with both the old and new algorithm, and there is no measurable difference: it's basically dependent only on the length of the string, meaning that performance should be improved thanks to the deduplication.
If the path does exist, the algorithm is fast: I tested calling `set_env_prefix` and `set_env_suffix` back and forth with the same value (80 characters long) 1000 times, on an environment variable that is 3000 characters long: it takes only about 1.5 ms.
(Also, should this change apply only to the prefix and not the suffix?)
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
[^1]: Yes I already tried to contact them, yes they ignored me.
