This is my first Nix package, so happy to receive some feedback.
Annin
6599
Would appreciate it if someone could merge this update!
crertel
6600
Super easy; version bump + upgrade script fix. Merge too if you have a commit bit. <3
Zonni
6602
New version + fixed file pickers (tested under gnome)
Don’t bother the big +40939. It’s mostly from a database-file for the test.
Note: It may be worth it to just read the nixos/modules/services/security/crowdsec.nix alone, not the diff since it’s mostly rewritten.
musjj
6609
1-line PR to add a package to the hydra cache
Just bumping this as I had a review from @Sandro . If you could re-review the changes made after your comments, that would be great! Thank you!
