Woot woot! I’m really excited about this! OBS background remover working great with AMD cards.
Here is one of my very unimpressed dogs as an example (doh. that’s not supposed to be a middle finger, i swear )
master ← randomizedcoder:obs-backgroundremoval-1.3.7
opened 07:00AM - 24 Mar 26 UTC
Really happy to share this update. After bumping obs-backgroundremoval to 1.3.7 … and enabling GPU acceleration, background removal on OBS is looking great. On an AMD Radeon W7500, GPU utilization sits at roughly 10%, compared to the previous version (1.1.13) which would saturate all cores on a 24-core machine running CPU-only inference.
- Bump version to 1.3.7 (latest upstream)
- Remove cmake preset and custom build/install phases
- Remove DISABLE_ONNXRUNTIME_GPU flag (no longer exists upstream)
- Add pkg-config to nativeBuildInputs (required for dependency discovery)
- GPU execution providers (ROCm, MIGraphX, CUDA, TensorRT) are now auto-detected at build time via the linked onnxruntime
- Update homepage URL to current GitHub org (occ-ai)
- Add randomizedcoder to maintainers
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- Nixpkgs Release Notes
- NixOS Release Notes
Small package update PR, just a simple version update. #497653
I would appreciate it if someone could validate
master ← Mistyttm:update-tdarr
opened 08:09AM - 01 Mar 26 UTC
Updated the update script to actually work properly. It ran into issues with non… -ASCII characters. And also updated to the latest version
## Things done
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [X] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [X] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
I would love to get this one merged, it has a pretty crtitical update script fix
Hello,
I have several PR ready for review:
master ← nyanloutre:patch-1
opened 09:40AM - 16 Jan 26 UTC
My CPU does not have AVX2 support which seems to be enabled in the tensorflow bu… ilds.
This leads to a core dump if trying to import libtensorflow. Programs depending on libtensorflow will also crash with a core-dump without printing any message (photoprism).
It would be better to mark this package as broken for CPU without AVX2 support and prevent broken systems.
My CPU:
https://www.intel.fr/content/www/fr/fr/products/sku/97937/intel-atom-processor-c3558-8m-cache-up-to-2-20-ghz/specifications.html#specs-1-0-7
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
release-25.11 ← nyanloutre:beszel-cve-fix-backport
opened 09:37AM - 24 Mar 26 UTC
Fixes https://github.com/NixOS/nixpkgs/issues/495282 / https://github.com/adviso… ries/GHSA-phwh-4f42-gwf3
Test is failing on unstable too (fix is in https://github.com/NixOS/nixpkgs/pull/502990)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
master ← nyanloutre:beszel-fix-test
opened 10:06AM - 24 Mar 26 UTC
fix for failing test
## Things done
- [x] x86_… 64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] [NixOS tests] in [nixos/tests].
master ← nyanloutre:missing-networkd-option
opened 02:23PM - 24 Mar 26 UTC
https://www.freedesktop.org/software/systemd/man/latest/systemd.netdev.html#%5BV… LAN%5D%20Section%20Options
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
luana
March 25, 2026, 4:25pm
6627
Hii it’d be cool if someone reviewed this :3
master ← LuNeder:catask
opened 08:35PM - 23 Jan 26 UTC
Add catask, a webapp for questiowons and answers: [catask.org](https://catask.or… g)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] Module addition: when adding a new NixOS module.
Any Framework laptop/desktop users out here that could help me get this reviewed and merged?
master ← ozturkkl:framework-control
opened 04:29AM - 15 Mar 26 UTC
Adds `framework-control` (https://github.com/ozturkkl/framework-control), a ligh… tweight web-based control surface for Framework laptops/devices. It wraps `framework-tool` to expose fan curve control, battery charge limits, power management, and hardware telemetry via a local web UI served on `127.0.0.1:30912`.
Also adds a NixOS module at `services.framework-control.enable`. This app is meant to run as a system service since it needs access to the `framework_tool` CLI commands that talk to the Embedded Controller.
## Things done
- [x] x86_64-linux (Framework devices are only available with this platform)
- [ ] aarch64-linux
- [ ] x86_64-darwin
hekazu
March 25, 2026, 7:07pm
6629
My second package looks to coincidentally have been Rust based as well, only this time I also had the privilege of seeing how to make the GUI work. I’d appreciate a review, now that I’ve ironed out the kinks with differences between Wayland and XServer.
master ← hekazu:add-raphael-xiv
opened 11:27AM - 10 Mar 26 UTC
Raphael XIV is a crafting macro solver for Square Enix's MMORPG Final Fantasy XI… V. It includes both GUI and CLI options. https://github.com/KonaeAkira/raphael-rs
## Things done
The package builds and the GUI is confirmed to run on Wayland and X11 with Vulkan. The solver produces results as expected. Additionally the CLI is also built as part of the package.
- [X] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [X] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
