A fix for herdr so it can be installed on MacOS devices
master β arunoruto:herdr
opened 12:18PM - 27 Jun 26 UTC
herdr wasn't building on Darwin systems as can be see in these hydra logs: https⦠://hydra.nixos.org/build/332986051/nixlog/1
To fix this, I added an Xcode select script inspired by the upstream repo and their `package.nix` and the cctools. With this, the problem has been fixed.
I also added a versionCheckHook just in case (I guess rust projects don't need it really, but better to be safe than sorry).
I checked the licence of the project, and it is an `agpl3Plus`, not `agpl3Only`.
## Things done
- Built on platform:
- [ ] x86_64-linux
- [ ] aarch64-linux
- [x] aarch64-darwin
- Tested, as applicable:
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
- [ ] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
Refactor the new stump package so it uses finalAttrs as intended and add auto updates
master β arunoruto:stump
opened 12:28PM - 23 Jun 26 UTC
While the functional behaviour was introduced, the stump package hasn't been usi⦠ng it much and instead utilized a let-in block.
The contents of the let-in block has been moved inside and the derivation function and the `finalAttrs` argument has been used where needed.
This enables easier automatic updates using nix-update-script.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] aarch64-darwin
Adds the RVGL launcher, thank you.
master β andrew-field:add-rvgl-launcher
opened 04:16PM - 20 Mar 26 UTC
This pull request adds the launcher and package manager for RVGL, the port of th⦠e Re-Volt video game.
Parent homepage: https://re-volt.gitlab.io
Homepage: https://re-volt.gitlab.io/rvgl-launcher
Download page: https://gitlab.com/re-volt/rvgl-launcher
Related site: https://rvgl.org
## Things done
- [x] x86_64-linux
- [x] aarch64-linux
- [ ] x86_64-darwin
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
## Notes
- I have only been able to test on GNU/Linux, I don't know if it works on Darwin. That is why the platforms listed only include GNU/Linux at the moment.
- Tested with a keyboard and an Xbox controller and only offline so far.
- The game itself runs perfectly well when launched, although the log gives the warning:
Error loading libFLAC.so.12: libFLAC.so.12: cannot open shared object file: No such file or directory
Error loading libFLAC.so.8: libFLAC.so.8: cannot open shared object file: No such file or directory
I have been unable to solve this warning. Adding `flac` to the targetPkgs does not provide those old libraries and I know of no extra commands to try to patch/link the old libraries to the new ones. The upstream binary where the hard linking is made to those old libraries also appears unavailable.
- The unwrapped section works well in a non-FHS environment but the game itself when launched seems to require an FHS environment which is why there is a wrapped and non-wrapped section. I hope I have written the recipe correctly to provide both parts.
- The gtk3 package is not strictly needed in the target packages but it will write constant errors to the log without it.
- The p7zip package in the target packages is only needed by the actual game when launched, to manage the RVGL packages the game itself uses.
init the Databend command line query utils, thanks
master β mnixry:bendsql-init
opened 10:34AM - 02 Jul 26 UTC
Add `bendsql` 0.34.0, Databend's native command-line client. Packaged from crate⦠s.io with `rustPlatform.buildRustPackage`, using nixpkgs SQLite instead of bundled SQLite.
Assisted-by: OpenAI Codex
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
- [x] [Package tests] at `passthru.tests`.
- [x] Follows the [automation/AI policy].
There is a pending review for nixpkgs from my side:
master β Myxogastria0808:master
opened 10:44AM - 02 May 26 UTC
Add elm-watch, that recompiles whenever your Elm files change and reloads the co⦠mpiled JS in the browser.
Homepage: https://github.com/lydell/elm-watch#readme
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I created a new PR for explo, superseding the previous one (mentioned in my PR).
I added the new changes in there and I have it working for a few weeks now
master β arunoruto:explo
opened 12:00PM - 03 Jul 26 UTC
Supersedes #421299
Adds my mentioned fixes for the derivation and updates it⦠to the latest available versin. Should be automatically updated in the future :)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
I am still waiting on approval for my first-time contribution. I think all kinks have been worked out by now. If anyone has some time, Iβd really appreciate a review! Thanks!
master β fstracke:master
opened 04:40PM - 05 Jun 26 UTC
This pr updates the hamlib package to version 4.7.1.
To enable this update, the⦠package wsjtz - depending on hamlib - was updated to version 2.0.14.
Both repositories have changed their primary host to github, which is reflected in the pr.
I added myself as maintainer for both packages as I now need to use them regularly and can add updates when released.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
