74k1
July 7, 2026, 6:23am
7190
the Sure.am (personal finance tool) NixOS module for an existing nix package. (Would appreciate feedback, as this is our first module PR for nixpkgs.)
Thank you for your time.
master β pjrm:nixossure
opened 08:56AM - 17 Jun 26 UTC
New package/module: sure
Homepage URL: https://sure.am/
source URL: https://β¦ github.com/we-promise/sure
license: AGPL-3.0
plataforms: linux
description: The personal finance app for everyone.
I've taken inspiration from Gitlab/Dawarich package.
## Things done
- Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- Tested, as applicable:
- [ ] Tested basic functionality of all binary files, usually in `./result/bin/`.
- Nixpkgs Release Notes
- NixOS Release Notes
- [ ] Fits [CONTRIBUTING.md], [pkgs/README.md], [maintainers/README.md] and other READMEs.
- [ ] Follows the [automation/AI policy].
[automation/AI policy]: https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#automationai-policy
After sitting for a long time waiting for upstream fixes, this pr is finally ready!
master β flashonfire:update-oxicloud
opened 08:55AM - 24 Jun 26 UTC
Updated package to 0.8.1
Migrated to the new frontend
Closes #532090
## T⦠hings done
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] Ran `nixpkgs-review` on this PR. See [nixpkgs-review usage].
- [x] Follows the [automation/AI policy].
backport hinoirisetr to 26.05:
release-26.05 β backport-521988-to-release-26.05
opened 09:36PM - 14 Jun 26 UTC
Bot-based backport to `release-26.05`, triggered by a label in #521988.
**Befor⦠e merging, ensure that this backport is [acceptable for the release](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#changes-acceptable-for-releases).**
Even as a non-committer, if you find that it is not acceptable, leave a comment.
> [!TIP]
> If you maintain all packages touched by this pull request, and they are all located under `pkgs/by-name/*`, you can comment **`@NixOS/nixpkgs-merge-bot merge`** to automatically merge this PR using the [`nixpkgs-merge-bot`](https://github.com/NixOS/nixpkgs/blob/master/ci/README.md#nixpkgs-merge-bot).
{rakudo,npq,zef,moarvm} version bumps
master β vavakado:raku-updates
opened 01:44PM - 21 Jun 26 UTC
Supersedes #504598.
Release notes:
- zef: https://github.com/ugexe/zef/compa⦠re/v1.0.0...v1.1.3
- rakudo: [2026.03](https://github.com/rakudo/rakudo/releases/tag/2026.03), [2026.04](https://github.com/rakudo/rakudo/releases/tag/2026.04), [2026.05](https://github.com/rakudo/rakudo/releases/tag/2026.05)
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
SeTSeR
July 7, 2026, 5:56pm
7196
master β SeTSeR:far2l-plugins
opened 07:44PM - 28 Jun 26 UTC
Enable far2l plugins brought with recent updates. Export library required for fa⦠r2l Arclite plugin from _7zz package.
PR is based on #519180.
Closes #447724.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
There was a change request, but it is not relevant anymore, as I removed related change, but maintainer doesnβt react. Otherwise I have needed approves it seems.
Package already reviewed, but first backport PR needs to be manually merged:
release-26.05 β backport-481474-to-release-26.05
opened 06:25PM - 29 Jun 26 UTC
Bot-based backport to `release-26.05`, triggered by a label in #481474.
> [!TIP]
rxda
July 8, 2026, 1:44am
7199
HelloοΌmy PR has been waiting for 3 months. Could anyone spare some time to review it? Itβs rebased and ready to go. Much appreciated! I need to be a contributor to submit other packages.
master β rxda:add-bili-downloader-maintainer
opened 04:52AM - 10 Apr 26 UTC
## Things done
- [x] x86_64-linux
- [ ] aarch6β¦ 4-linux
- [ ] x86_64-darwin
Hello,
I have this PR already reviewed by a non-committer, can I have a commiter review, please?
master β blackheaven:nanobot/init-0.2.2
opened 10:47PM - 04 Jul 26 UTC
## Things done
Adding https://github.com/HKUDS/nanobot package and module
β¦ - Built on platform:
- [x] x86_64-linux
- [ ] aarch64-linux
- [x] [NixOS tests] in [nixos/tests].
- [x] [Package tests] at `passthru.tests`.
- [x] Module addition: when adding a new NixOS module.
Hi, I have a PR open since April 2025 which already has non-committer reviews. I rebased just now. Could a committer please take a look? Many thanks!
master β lordkekz:syncthing-apiKey
opened 09:54PM - 25 Apr 25 UTC
There is currently no way to set syncthing's apiKey without leaking it to the Ni⦠x store.
For example, https://github.com/Martchus/syncthingtray requires an API key (but can even access remote instances!).
This PR:
- Adds `services.syncthing.apiKeyFile` to make it possible to securely set api keys for syncthing instances.
- Using the insecure `services.syncthing.settings.gui.apiKey` option now throws an error pointing to the new option.
- Fixes #401745.
- Changes the test `syncthing-init` (maintainer @Lassulus ) to also test the new option.
## Things done
- Built on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [x] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
yvnth
July 8, 2026, 4:56pm
7203
Should be good to go. Itβs a pretty popular package, and easy to maintain.
master β Ghastrum:add-torlink
opened 11:15PM - 02 Jul 26 UTC
# [torlink](https://github.com/baairon/torlink)
Torlink is a torrent finder tha⦠t lives in your terminal, with zero setup and nothing to configure.
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
MartV
July 10, 2026, 10:50am
7209
My first contribution, very small patch adding a secret file option. Would be nice if somebody could have a look
master β MartV0:isso-secret-file
opened 02:59PM - 03 Jul 26 UTC
Added a secret file option to the isso service. This was currently lacking meani⦠ng secrets had to be defined in the normal nix config, which would leak them into the nix store. I took some inspiration from the listmonk option with the same name <https://github.com/NixOS/nixpkgs/blob/master/nixos/modules/services/mail/listmonk.nix>. I tested it locally on my server and it works, see the testing branch here: <https://github.com/MartV0/homelab/compare/isso-secret-file>. This is my first ever nix pull request so any feedback is more than welcome.
## Things done
- [ ] x86_64-linux
- [ ] aarch64-linux
