I created a derivation that rebuilt GHC with a newer version of clang than it was using by default:
In doing so, I had to override some of the cross-compilation-related arguments to GHC, like targetPackages and pkgsBuildTarget.
I have read the cross-compilation section of the nixpkgs manual, but I still don’t really understand what is going on.
I had a couple specific questions come up while doing this, and I’d be really interested in answers to them:
What are
targetPackages,pkgsBuildTarget,buildPackages, etc? Where are they defined? When not doing cross compilation, do they all end up being the same thing? -
Is it safe to override things like
targetPackages,pkgsBuildTarget, etc in an overlay to nixpkgs? Is there anything I should watch out for when doing this?For example, if I wanted to make sure I built a compiler using a different
stdenv, do I have to override thestdenvin the normal top-level attribute-set, thetargetPackagesattribute set, and thepkgsBuildTargetattribute set?I ended up directly modifying arguments to GHC in How to get llvm-hs building on MacOSX in nixpkgs instead of using an overlay. It was tricky to figure out. Is there some easier way to do this?
The GHC derivation takes arguments of
pkgsBuildTarget,targetPackages, andbuildLlvmPackages(which gets passed in asbuildPackages.llvmPackages). Why doesn’t GHC just takebuildPackagesas an argument and pullllvmPackagesout of it?Alternatively, why doesn’t GHC just take the individual packages it needs from
pkgsBuildTargetandtargetPackagesas arguments instead of taking the whole set? -
The GHC derivation pulls out a separate
targetPackagesfrompkgsBuildTarget:What is going on here? Is
pkgsBuildTarget.targetPackagesdifferent fromtargetPackages? -
In the top-level
haskell-packages.nixfile, why iscallPackageredefined:I imagine this doesn’t have anything to do with cross-compilation stuff, but I was still wondering…
In the top-level
haskell-packages.nixfile, when the haskell package sets are created, they are given a reference to GHC frombuildPackages.haskell.compiler.ghc865:Why can’t they just take the compiler from
haskell.compiler.ghc865? Why specificallybuildPackages.haskell.compiler.ghc865? -
In the top-level
haskell-packages.nixfile, when the haskell package sets are created, they are given a reference tobuildPackages.haskell.packages.ghc865calledbuildHaskellPackages:What is this? Is
buildPackages.haskell.packages.ghc865different fromhaskell.packages.ghc865? If not, then isn’t this just a circular reference? How come this doesn’t give an infinite recursion error when it is used? Is it due to nix’s laziness?
I guess I should ping people I’ve seen talk about cross compilation stuff, since they would probably know the answers to these questions: @peti, @matthewbauer, @Ericson2314 (Recently @peti has been doing weekly streams where he works on Haskell stuff. I’d love to see a long-form video explanation of the types of things I asked above.)
