Troubleshooting: Kde/Qt issues. using hm and pm
Hi!
For a while, on my nixos installation there seem to be invalid Qt versions after booting, but only until I’ve done nixos-rebuild switch again. That is, I’m not sure if something is wrong with the boot or… whatever, actually.
Please give me some pointers what I should look out for, because I’m totally at a loss how to even diagnose what’s going on.
Symptoms
  • before switching: kate config looks off (weird defaults?) until after switching.
  • both before and after switching: kde connect complains about mismatching qt versions
  • after switching: nheko fails (critical] Failed to initialize graphics backend for OpenGL. (:0, ))
I would love to finally fix this, and I have no idea where to even start searching.
My config
Interestingly, I have two very similar configs, only one of them being affected.
My main config repo
I use home-manager (standalone) and plasma-manager.
There are a bunch of warning in the journal, but no clear-cut “this is the error”
Excerpts from the journal after booting:
qt.qpa.wayland: Could not create EGL surface (EGL error 0x3003)
QDBusObjectPath: invalid path "/modules/plasma-session-shortcuts"
kf.dbusaddons: The kded module name "plasma-session-shortcuts" is invalid!
 org.kde.powerdevil.discretegpuhelper[2810]: Detected locale "C" with character encoding "A>
        Qt depends on a UTF-8 locale, and has switched>
        If this causes problems, reconfigure your loca>
        for more information.
plasmashell[2728]: file:///nix/store/ghpzrhj5cw7jzmcvajq0bf4w98icymjm-plasma-desktop-6.3.3>
backlighthelper[2836]: org.kde.powerdevil: no kernel backlight interface found
file:///nix/store/ghpzrhj5cw7jzmcvajq0bf4w98icymjm-plasma-desktop-6.3.3/share/plasma/plasmoids/org.kde.desktopcontainment/contents/ui/main.qml:201:9
plasmashell[2728]: Toolbox not loading, toolbox package is either invalid or disabled.
kded6[2708]: org.kde.kameleon: found no RGB LED devices
kconf_update[2939]: kf.config.kconf_update: /run/current-system/sw/share/kconf_update/ark.upd defined Version=5 but Version=6 was expected
kconf_update[2939]: kf.config.kconf_update: /run/current-system/sw/share/kconf_update/dolphin_detailsmodesettings.upd defined Version=5 but Version=6 was expected
kconf_update[2939]: kf.config.kconf_update: /run/current-system/sw/share/kconf_update/dolphin_directorysizemode.upd defined Version=5 but Version=6 was expected
kalendarac[2881]: qt.multimedia.symbolsresolver: Couldn't load pipewire-0.3 library
kalendarac[2881]: qt.multimedia.symbolsresolver: Couldn't resolve pipewire-0.3 symbols
kconf_update[2939]: kf.config.kconf_update: /run/current-system/sw/share/kconf_update/konsole.upd defined Version=5 but Version=6 was expected
kconf_update[2939]: kf.config.kconf_update: /run/current-system/sw/share/kconf_update/okular.upd defined Version=5 but Version=6 was expected
Avoid mixing stable with unstable, that may resolve your issue.
24.11 has also long been unsupported, the current stable is 25.05.
thanks!
that fixes the “nheko being weird” part, but sadly not more than that
issues are apparently mismatched qt versions. more here: Mismatching Qt versions between home-manager and system nixpkgs
