In order to save disk space by reducing my store’s (/nix/store/) disk usage, I’d like to use a single channel for both my system (whatever is used for nixos-rebuild) and for my only (real) user’s nix-env.
I’m not sure I got right what’s documented hence I’m asking here. Here’s some info of my current channels state:
maybe just remove user channel? It will fallback to system one
What’s the meaning of the symlink to default-5-link in the profiles directory?
each time you rebuild profile, a new symlink is created - system-1-link, system-2-link, … The system symlink just refers to latest system-NN-link. When you nix-collect-garbage -d, it removes those intermediate unused symlinks, so you are left with only latest and link to latest.
It seems that nix-channel --remove nixpkgs didn’t make nix-env --upgrade fail but I think now I’m left with no updates at all. I ran nixos-rebuild and I think it upgraded every possible package. Yet nix-env --upgrade hasn’t updated a single one.
But it’s impossible that I’ve had only 5 generations through out my usage of packages - I’m using NixOS for at least a year and I’ve tested hundreds of times programs using nix-env -iA and then nix-env -e.
With the nixpkgs channel I had from before, I get 1 update. Maybe that’s a sign of that small gap between nixos-unstable and nixpkgs-unstable… Meaning it’s OK that nix-env --upgrade think there’s nothing to upgrade.
(EDIT) Moreover, I’m trying to investigate while at it, the issue of multiple search results in nix search - Why now, even with only 1 channel for root and no channels for myself, I get 3 search results from 3 channels:
* nixos-unstable.blender (blender)
3D Creation/Animation/Publishing System
* nixos.blender (blender)
* nixpkgs.blender (blender)
not sure if you talk about user profile or root profile. Because default-5-link is root profile, that is sudo nix-env -i .... It might be you rarely install anything as root.
The nixos-unstable channel looks like a bug. It should have been removed by nix tools… But duplication nixos/nixpkgs is kinda expected - I believe this is an old bug.
I see. Say @danbst I’d like to file a bug in Issues · NixOS/nix · GitHub , where should I start? What info is relevant? Should I tell them my $NIX_PATH as well? It is set by /etc/set-environment as generated by my NixOS config… Currently:
$HOME/.nix-defexpr/channels lets you use <channelname> to refer to user channels you got from nix-channels, and /nix/var/nix/profiles/per-user/root/channels also does that but lets regular users use root’s channels, that is those configured with sudo nix-channels. nixos-config=/etc/nixos/configuration.nix lets nixos-rebuild, nixos-options etc. find the configuration file.
It does not. $NIX_PATH is several ‘things’ separated by :, and each ‘thing’ is either path or name=path. Please see my earlier reply again for what /nix/var/nix/profiles/per-user/root/channels does, and also the relevant section in the Nix manual.
Do you think @dramforever I’d miss something with this $NIX_PATH? Would I have trouble if I’d want to use all kinds of default.nix files in development repos that use import <channelname>?
Actually IIRC the default configuration is exactly what you described in your original post title: only 1 channel for user nix-env and system nixos-rebuild. If the user doesn’t configure any channels, root’s ones are used. You didn’t really have to do anything .
$NIX_PATH is like that because nix-channel is a completely separate mechanism. It would actually complicate things if in Nix <foo> referred to some ‘channel’ mechanism rather than just a path configured by an environment variable.
As of your NIX_PATH, I don’t see a problem. If it’s working for you then it’s most likely fine. The only NIX_PATH you can expect existing from most installations is <nixpkgs> anyway, so I think it’s okay.
I agree with you it is all complicated. I think this is one of reasons why nix-channel and nix-env were not ported to Nix2, and why all this flakes + flake locks stuff is going on. So maybe don’t report a bug, but let’s just wait until flakes+nix2 stabilize.
My default $NIX_PATH includes paths without a something= and I think that’s what caused the multiple search results in nix search. As for the original issue of this thread, I can testify that currently:
$ nix-channel --list
Outputs nothing but:
$ ls -l ~/.nix-defexpr/channels/
total 12
lrwxrwxrwx 2 root root 99 Jan 1 1970 binary-caches -> /nix/store/n8q83dx47i6n562l9q23ppf2c92i0112-nixos-unstable-19.09pre186563.b5f5c97f7d6/binary-caches
lrwxrwxrwx 2 root root 60 Jan 1 1970 manifest.nix -> /nix/store/fshsa1v74jv8b9ssjnq1yf783lfdissg-env-manifest.nix
lrwxrwxrwx 2 root root 100 Jan 1 1970 nixos-unstable -> /nix/store/n8q83dx47i6n562l9q23ppf2c92i0112-nixos-unstable-19.09pre186563.b5f5c97f7d6/nixos-unstable
Maybe that’s the bug @danbst talked about in post #5? I expect the nixos-unstable directory not to be there.
That’s definitely helpful @danbst . It’ll take me some time though to get my head wrapped around it along @tohl2’s suggestion. What perplexes me the most is the fact that nix-env doesn’t care about $NIX_PATH. That’s pretty insane. Hence I’m considering:
Yes this does not look right to me. If you can cause this without doing anything funny like editing ~/.nix-channels by hand then it’s a bug. If you did do something funny though, you might consider it a bug but I guess you’re supposed to clean up after yourself…
I suppose it could be set via nix.nixPath (as @tohl2 suggested):
In the current state:
I don’t get duplicate search results from nix search and only the nixos. attribute prefix is used in it’s results.
nix-env -qa --json is showing only nixos. attributes which are all derived from the packages defined in /nix/var/nix/profiles/per-user/root/channels/nixos.
command-not-found is using the nixos. attribute to instruct how to install a package.
