lion
March 17, 2024, 9:34am
1
@mythmon I’ve seen you have this issue before with Minecraft
The flickering is caused by the lack of explicit sync on Wayland with Nvidia drivers.
Related Gitlab issues: Explicit GPU Synchronization for DRI3, Present, and Xwayland (!967) · Merge requests · xorg / xserver · GitLab
linux-drm-syncobj-v1: new protocol (!90) · Merge requests · wayland / wayland-protocols · GitLab
Both the wayland-protocols merge request and the v555 Nvidia driver are required in tandem to remove flickering.
lion
March 17, 2024, 9:35am
2
The merge requests will also (hopefully) fix any flickering you experience on Electron applications.
zelda
July 10, 2024, 4:47pm
3
when will it be integrated into nixos?
oh wow! I’ve been waiting for this for so long I’ve given up nvidia+wayland combination, seeing how some discussion threads date back 4-6 years ago
P.S. oh, i even remembered I’ve posted a question about it in this forum: XWayland+Nvidia jitter mitigation question
workaround was to use __GL_MaxFramesAllowed=1 that caused terrible performance drop and still did not fix missing redraws in programs that called redraw on certain events only
lion
February 14, 2025, 3:05pm
5
Solved using NVIDIA - NixOS Wiki . The fix is still not in the stable version. This old issue is causing new users a lot of problems.
