This is a naive idea: can we automatically generate an intermediate, unwrapped package right after package build (before postBuild)? This could potentially be realized in the mkDerivation internals without any user facing API changes.
Rationale: Since the actual package build is usually the most resource intensive / time-consuming part of writing / tweaking / overriding a package, it would be quite nice to reuse the build results as long as everything before preBuild has not changed.
Also, in nixpkgs there are a lot of unwrapped packages + wrappers constructed with symlinkJoin and the likes, precisely to avoid this problem of rebuilding the binaries. That’s a lot of boilerplate! Many of them can be simplified if things after postBuild are low-cost operations: one can just .overrideAttrs without rebuilding the whole package.
Implementations: I have no idea about the mkDerivation internals, so this is just a sketch of a possible way of implementing this idea:
- When
mkDerivationis called on somepackage, generate apackage-vanilladerivation with everything after (and including)postBuildstripped, and generate the usualpackagederivation by wrappingpackage-vanilla. - When building the package,
package-vanillais first built, copied into a new store for the eventualpackage(do not symlink to avoid possible issues), and thepostBuildcommands are applied to generate the finalpackage. - This new behavior can be protected behind a
mkDerivationflag such asvanillaPackage = true;
What do you think? Again, I am relatively new to nix, and this might be an unrealistic idea; if this is the case, please let me know!
Update: as pointed out by @shamrocklee something similar is introduced very recently:
https://github.com/NixOS/nixpkgs/pull/167670
Documentation: https://github.com/NixOS/nixpkgs/blob/master/doc/build-helpers/special/checkpoint-build.section.md
