Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X.Org X Server 1.21.1.11
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X Protocol Version 11, Revision 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Current Operating System: Linux Windows11 6.6.22 #1-NixOS SMP PREEMPT_DYNAMIC Fri Mar 15 18:25:07 UTC 2024 x86_64
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Kernel command line: init=/nix/store/j3iw5vg4l179qqp15599bzhh47qz752s-nixos-system-Windows_11-24.05.20240321.0930514/init udev.log_level=3 loglevel=4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Current version of pixman: 0.43.2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Before reporting problems, check http://wiki.x.org
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: to make sure that you have the latest version.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Markers: (--) probed, (**) from config file, (==) default setting,
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (++) from command line, (!!) notice, (II) informational,
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (WW) warning, (EE) error, (NI) not implemented, (??) unknown.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (++) Log file: "/dev/null", Time: Wed Mar 27 06:42:01 2024
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (++) Using config file: "/nix/store/wz1aw6z18z4fblq563qzl0ls42vwywcg-xserver.conf"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Using config directory: "/etc/X11/xorg.conf.d"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Using system config directory "/nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/share/X11/xorg.conf.d"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) ServerLayout "Layout[all]"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) |-->Screen "Screen-amdgpu[0]" (0)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) | |-->Monitor "<default monitor>"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) | |-->Device "Device-amdgpu[0]"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) No monitor specified for screen "Screen-amdgpu[0]".
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Using a default monitor configuration.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) |-->Screen "Screen-vmware[0]" (1)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) | |-->Device "Device-vmware[0]"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) No monitor specified for screen "Screen-vmware[0]".
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) |-->Screen "Screen-virtualbox[0]" (2)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) | |-->Device "Device-virtualbox[0]"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) No monitor specified for screen "Screen-virtualbox[0]".
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) |-->Screen "Screen-modesetting[0]" (3)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) | |-->Device "Device-modesetting[0]"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) No monitor specified for screen "Screen-modesetting[0]".
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) |-->Input Device "VBoxMouse"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) Option "DontZap" "on"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) Option "AllowMouseOpenFail" "on"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Automatically adding devices
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Automatically enabling devices
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Automatically adding GPU devices
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Automatically binding GPU devices
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) Max clients allowed: 256, resource mask: 0x1fffff
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) ModulePath set to "/nix/store/ai5aa6yivxmba2s1qzb95anj4mry5gcz-xf86-video-vboxvideo-1.0.0/lib/xorg/modules/drivers,/nix/store/fvy3f8y5bazd3chfvciykq4rywlc7bqw-xf86-video-vmware-13.4.0/lib/xorg/modules/drivers,/nix/store/h9y1zi7ib62zgc5ipsqh69qwzjrv9nds-xf86-video-amdgpu-23.0.0/lib/xorg/modules/drivers,/nix/store/jaif81646dykd6bz3wnafhk8jnz8ydn7-xf86-input-evdev-2.10.6/lib/xorg/modules/input,/nix/store/kzwziwwpb00fvqn7y7ysabw1pz3ckikz-xf86-input-libinput-1.4.0/lib/xorg/modules/input,/nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules,/nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/drivers,/nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/extensions,/nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/input"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) The server relies on udev to provide the list of input devices.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: If no devices become available, reconfigure udev or disable AutoAddDevices.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loader magic: 0x63fe40
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module ABI versions:
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X.Org ANSI C Emulation: 0.4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X.Org Video Driver: 25.2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X.Org XInput driver : 24.4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: X.Org Server Extension : 10.0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (++) using VT number 2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) xfree86: Adding drm device (/dev/dri/card1)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:02.0/drm/card1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) xfree86: Adding drm device (/dev/dri/card0)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Platform probe for /sys/devices/pci0000:00/0000:00:07.0/0000:02:00.0/0000:03:01.0/0000:04:00.0/0000:05:00.0/0000:06:00.0/drm/card0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (--) PCI:*(0@0:2:0) 8086:46a6:103c:89dd rev 12, Mem @ 0x601c000000/16777216, 0x4000000000/268435456, I/O @ 0x00004000/64, BIOS @ 0x????????/131072
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (--) PCI: (6@0:0:0) 1002:731f:103c:89dd rev 193, Mem @ 0x4200000000/8589934592, 0x4100000000/2097152, 0x52000000/524288, I/O @ 0x00003000/256, BIOS @ 0x????????/131072
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) "glx" will be loaded by default.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "glx"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/extensions/libglx.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module glx: vendor="X.Org Foundation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: compiled for 1.21.1.11, module version = 1.0.0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: ABI class: X.Org Server Extension, version 10.0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "amdgpu"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/h9y1zi7ib62zgc5ipsqh69qwzjrv9nds-xf86-video-amdgpu-23.0.0/lib/xorg/modules/drivers/amdgpu_drv.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module amdgpu: vendor="X.Org Foundation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: compiled for 1.21.1.11, module version = 23.0.0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Module class: X.Org Video Driver
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: ABI class: X.Org Video Driver, version 25.2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "vmware"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/fvy3f8y5bazd3chfvciykq4rywlc7bqw-xf86-video-vmware-13.4.0/lib/xorg/modules/drivers/vmware_drv.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module vmware: vendor="X.Org Foundation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: compiled for 1.21.1.11, module version = 13.4.0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "vboxvideo"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/ai5aa6yivxmba2s1qzb95anj4mry5gcz-xf86-video-vboxvideo-1.0.0/lib/xorg/modules/drivers/vboxvideo_drv.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module vboxvideo: vendor="Oracle Corporation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: compiled for 1.21.1.11, module version = 1.0.1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (**) Load address of symbol "VBOXVIDEO" is 0x7f24c9cd5320
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "modesetting"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/drivers/modesetting_drv.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module modesetting: vendor="X.Org Foundation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: compiled for 1.21.1.11, module version = 1.21.1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "vboxmouse"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (WW) Warning, couldn't open module vboxmouse
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Failed to load module "vboxmouse" (module does not exist, 0)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU: Driver for AMD Radeon:
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: All GPUs supported by the amdgpu kernel driver
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) vmware: driver for VMware SVGA: vmware0405, vmware0710
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) VBoxVideo: guest driver for VirtualBox: vbox
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modesetting: Driver for Modesetting Kernel Drivers: kms
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): using drv /dev/dri/card1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Creating default Display subsection in Screen section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: "Screen-modesetting[0]" for depth/fbbpp 24/32
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): Depth 24, (==) framebuffer bpp 32
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): RGB weight 888
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): Default visual is TrueColor
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading sub module "glamoregl"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "glamoregl"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/lib/xorg/modules/libglamoregl.so
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module glamoregl: vendor="X.Org Foundation"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: ABI class: X.Org ANSI C Emulation, version 0.4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): glamor X acceleration enabled on Mesa Intel(R) Graphics (ADL GT2)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): glamor initialized
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): VariableRefresh: disabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): AsyncFlipSecondaries: disabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output eDP-1 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output HDMI-2 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output DP-4 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output DP-5 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID for output eDP-1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Manufacturer: AUO Model: a08b Serial#: 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Year: 2019 Week: 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID Version: 1.4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Digital Display Input
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 8 bits per channel
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Digital interface is DisplayPort
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Max Image Size [cm]: horiz.: 34 vert.: 19
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Gamma: 2.20
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): No DPMS capabilities specified
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Supported color encodings: RGB 4:4:4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): First detailed timing is preferred mode
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Preferred mode is native pixel format and refresh rate
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Display is continuous-frequency
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): redX: 0.566 redY: 0.339 greenX: 0.351 greenY: 0.568
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): blueX: 0.158 blueY: 0.121 whiteX: 0.313 whiteY: 0.329
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Manufacturer's mask: 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Supported detailed timing:
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): clock: 141.0 MHz Image Size: 344 x 193 mm
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): h_active: 1920 h_sync: 2028 h_sync_end 2076 h_blank_end 2100 h_border: 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): v_active: 1080 v_sync: 1090 v_sync_end 1100 v_blanking: 1116 v_border: 0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): clock: 94.0 MHz Image Size: 344 x 193 mm
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Unknown vendor-specific block 2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID (in hex):
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 00ffffffffffff0006af8ba000000000
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 001d0104a5221378033e859156599128
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 1f505400000001010101010101010101
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 010101010101143780b4703824406c30
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): aa0058c110000018b82480b470382440
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 6c30aa0058c110000018000000000000
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 00000000000000000000000000000002
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): 001430ff123cc80b0719c820202000bd
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Printing probed modes for output eDP-1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID for output HDMI-2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID for output DP-4
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): EDID for output DP-5
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output eDP-1 connected
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output HDMI-2 disconnected
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output DP-4 disconnected
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output DP-5 disconnected
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Using exact sizes for initial modes
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Output eDP-1 using initial mode 1920x1080 +0+0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): Using gamma correction (1.0, 1.0, 1.0)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): DPI set to (96, 96)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading sub module "fb"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "fb"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module "fb" already built-in
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): Depth 24, (--) framebuffer bpp 32
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): Default visual is TrueColor
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): RGB weight 888
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Using 8 bits per RGB (8 bit DAC)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (--) AMDGPU(G0): Chipset: "AMD Radeon RX 5700 XT" (ChipID = 0x731f)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading sub module "dri2"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "dri2"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module "dri2" already built-in
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): glamor X acceleration enabled on AMD Radeon RX 5700 XT (radeonsi, navi10, LLVM 17.0.6, DRM 3.54, 6.6.22)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): glamor detected, initialising EGL layer.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): TearFree property default: auto
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Output DisplayPort-1-0 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Output DisplayPort-1-1 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Output DisplayPort-1-2 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Output HDMI-A-1-0 has no monitor section
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): EDID for output DisplayPort-1-0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): EDID for output DisplayPort-1-1
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): EDID for output DisplayPort-1-2
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): EDID for output HDMI-A-1-0
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): mem size init: gart size :3e1804000 vram size: s:1fdcdd000 visible:1fdcdd000
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): DPI set to (96, 96)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): Using gamma correction (1.0, 1.0, 1.0)
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Loading sub module "ramdac"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) LoadModule: "ramdac"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Module "ramdac" already built-in
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) UnloadModule: "vmware"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Unloading vmware
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) UnloadModule: "vboxvideo"
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) Unloading vboxvideo
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): Backing store enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): Silken mouse enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): Initializing kms color map for depth 24, 8 bpc.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) modeset(0): DPMS enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): [DRI2] Setup complete
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): [DRI2] DRI driver: iris
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) modeset(0): [DRI2] VDPAU driver: va_gl
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): [DRI2] Setup complete
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): [DRI2] DRI driver: radeonsi
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): [DRI2] VDPAU driver: radeonsi
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Front buffer pitch: 4096 bytes
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): SYNC extension fences enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Present extension enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): DRI3 enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): Backing store enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Direct rendering enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Use GLAMOR acceleration.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (II) AMDGPU(G0): Acceleration enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): DPMS enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (==) AMDGPU(G0): Silken mouse enabled
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Backtrace:
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 0: /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/bin/X (OsSigHandler+0x29) [0x5b52c9]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) unw_get_proc_name failed: no unwind info found [-10]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 1: /nix/store/ksk3rnb0ljx8gngzk19jlmbjyvac4hw6-glibc-2.38-44/lib/libc.so.6 (?+0x0) [0x7f24ca3b4eb0]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 2: /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/bin/X (InitOutput+0x482) [0x488362]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 3: /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/bin/X (dix_main+0x190) [0x4496a0]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 4: /nix/store/ksk3rnb0ljx8gngzk19jlmbjyvac4hw6-glibc-2.38-44/lib/libc.so.6 (__libc_start_call_main+0x7e) [0x7f24ca39f0ce]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 5: /nix/store/ksk3rnb0ljx8gngzk19jlmbjyvac4hw6-glibc-2.38-44/lib/libc.so.6 (__libc_start_main+0x89) [0x7f24ca39f189]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) 6: /nix/store/rh9iw6jw9gbz9v00ryzgx2anmxkyv7zr-xorg-server-21.1.11/bin/X (_start+0x25) [0x432825]
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Segmentation fault at address 0x51
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Fatal server error:
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Caught signal 11 (Segmentation fault). Server aborting
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: Please consult the The X.Org Foundation support
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: at http://wiki.x.org
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: for help.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Please also check the log file at "/dev/null" for additional information.
Mar 27 06:42:01 Windows11 xserver-wrapper[2211]: (EE) Server terminated with error (1). Closing log file.
Mar 27 06:42:01 Windows11 systemd[1]: Started Process Core Dump (PID 2225/UID 0).
Mar 27 06:42:01 Windows11 systemd-coredump[2226]: Process 2211 (X) of user 0 dumped core.
