pawsen
November 19, 2024, 9:44pm
4860
Iโve got a trivial fix to make urh(Universal Radio Hacker) properly wrapped so that it works in unpolluted environments.
NixOS:master โ pawsen:urh_gsettings_fix
opened 09:37PM - 19 Nov 24 UTC
Fixes the GSettings errors
`GLib-GIO-ERROR **: No GSettings schemas are instaโฆ lled on the system (openscad:26805): GLib-GIO-ERROR **: 13:10:37.913: Settings schema 'org.gtk.Settings.FileChooser' is not installed`
by adding wrapGAppsHook3 so that the GLib schemas are available at runtime, otherwise it will crash when a file dialog is invoked in an unpolluted environment.
See [nixos discurse](https://discourse.nixos.org/t/gtk-file-dialog-causes-segfaults-glib-gio-error-settings-schema-org-gtk-settings-filechooser-does-not-contain-a-key-named-show-type-column/6853/7) for more info and [pull request](https://github.com/NixOS/nixpkgs/pull/293007) for similar fix.
^ Please summarise the changes you have done and explain why they are necessary here ^
## Things done
- Built on platform(s)
- [ ] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [ ] aarch64-darwin
- [ ] `sandbox = relaxed`
- [ ] `sandbox = true`
- [ ] Tested, as applicable:
- [25.05 Release Notes](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) (or backporting [24.11](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2411.section.md) and [25.05](https://github.com/NixOS/nixpkgs/blob/master/nixos/doc/manual/release-notes/rl-2505.section.md) Release notes)
Thanks a lot if you do!
k0kada
November 19, 2024, 9:48pm
4861
Second PR for the nixos-rebuild-ng , this one mostly focused to improve developer experience by adding nixos-rebuild-ng.passthru.devShell (this should make development much easier) and adding some minor features:
NixOS:master โ thiagokokada:nixos-rebuild-ng-pt-2
opened 01:48PM - 16 Nov 24 UTC
^ Please summarise the changes you have done and explain why they are neceโฆ ssary here ^
- Reduce build closure
- Add `nixos-rebuild-ng.devShell` to make it easier to develop
- Add `.version-suffix` update to classic Nix
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [x] aarch64-darwin
- [x] Tested, as applicable:
llakala
November 23, 2024, 3:01pm
4871
Fixes a broken application for 24.11
NixOS:master โ llakala:fix-extension-manager-2411
opened 07:44PM - 22 Nov 24 UTC
Fixes #357964. Be sure to backport to 24.11 :3
## Things done
- Builtโฆ on platform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
gepbird
November 23, 2024, 6:20pm
4872
Adds support for a proprietary tablet driver (nixos module + package(s)). Tested by people who have the required hardware, looking for reviewers
NixOS:master โ gepbird:xppen-init-v3-v4-nixos-module
opened 12:39PM - 27 Oct 24 UTC
## Summary
Add the official [XP Pen tablet](https://www.xp-pen.com/) drivers:โฆ `xppen_3`, `xppen_4` packages and `xppen` NixOS module.
## Prior work
This PR is based on #285660, thanks for @nasrally's, the reviewers' and the testers' work!
Closes #285660, closes #347984.
Related: #213263, #277176
## For reviewers
cc @h7x4, @MinerSebas, @eclairevoyant and @fsnkty for reviewing #285660
Differences to the aforementioned PR for the package:
- rename from `xppen` to `xppen_3`
- update from 3.4.9 (-231023) to 3.4.9-240131
- remove `libGL` dependency as it seems to be unused
- change `qt5.full` to `qt5.qtbase`
- refactor `installPhase`, merge with `postInstall`
- add maintainer gepbird
- remove `with lib;`
- change `meta.platforms` from linux to x86_64-linux
- add `meta.sourceProvenance`
- add comment for how to update the package
- nixfmt and order attrs
- squash commits, follow conventions
Differences for the NixOS module:
- add instructions to help users choose between the versions of the package.
- nixfmt
New changes:
- add `xppen_4`
- add release notes for module addition
The derivations for `xppen_3` and `xppen_4` are almost identical, but I'm not sure how to unify them in `by-name`, can I get some assistance?
## For testers
I don't have any XP Pen tablets, the most I can do is check whether the GUI opens. If you own a tablet, please test whether this works for you, feel free to ask for help if you're unsure how to do it.
cc @damiankorcz and @misumisumi for testing the version 3 driver
cc @HangedFool for testing the version 4 driver
To test it, you can build your system with this PR and with this extra config and you should see the `xppentablet` desktop entry or `PenTablet` binary:
```nix
programs.xppen = {
package = pkgs.xppen_3; # or `pkgs.xppen_4` for the newer driver
## Things done
- [x] x86_64-linux
- [x] (Module addition) Added a release notes entry if adding a new NixOS module
Fix spaCy transformer models, so that they work again (have been broken for a while). Probably worth backporting to 24.11 too.
NixOS:master โ danieldk:fix-spacy-models
opened 01:05PM - 17 Nov 24 UTC
Fix various issues with building spaCy models. The largest change is that spaCy โฆ 3.7.x has switched to using `spacy-curated-transformers` for transformer models in place of `spacy-transformers`. This change adds `spacy-curated-transformers` along with its dependensies `curated-transformers` and `curated-tokenizers`.
Besides that, this PR makes some smaller changes to `spacy-models` to make all models build again:
- Transformer models now use `spacy-curated-transformers`.
- `sl_core_news_trf` requires `protobuf` and `sentencepiece`.
- `ja` models require `sudachipy` and `sudachidict-core`
- Loosen the `pkuseg` requirement for `zh` models (0.3 -> 1.0 does not have API changes).
## Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
This one already had a review, but stalled after integrating the proposed changes:
NixOS:master โ danieldk:outlines-0.1.4
opened 03:52PM - 19 Nov 24 UTC
Update to the latest version of outlines.
## Things done
- Built on plโฆ atform(s)
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
I have one approval from a non-maintainer. Just looking for a maintainer.
NixOS:master โ lafrenierejm:aws-codeartifact-proxy
opened 06:35AM - 28 Apr 23 UTC
###### Description of changes
From the [package's homepage](https://github.coโฆ m/sktan/aws-codeartifact-proxy):
> An AWS code artifact proxy to allow unauthenticated read access to your code artifacts
###### Things done
- [x] x86_64-linux
- [ ] aarch64-linux
- [ ] x86_64-darwin
- [23.05 Release Notes (or backporting 22.11 Release notes)](https://github.com/NixOS/nixpkgs/blob/master/CONTRIBUTING.md#generating-2305-release-notes)
